Fuse, size, battery
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by Nanapoppypops, May 20, 2019.
  1. Nanapoppypops
    Nanapoppypops Member
    156
    Mar 30, 2019
    What's the best size fuse for your 12 volt battery
  2. nineoaks2004
    6,624
    2,577
    Graceville, Florida
    Usually 30 amp, sometimes 20 amp, some have a re-setable fuse
    theseus likes this.
  3. McFlyfi
    McFlyfi Active Member
    331
    126
    Aug 1, 2014
    Thousand Oaks CA
    30amp auto resetting.
  4. joet
    4,118
    709
    As said above, 30 amp fuse or 30 amp circuit breaker. Either are available from any auto parts store. And with a fuse, bigger is not better
  5. BillyMc
    BillyMc Well-Known Member
    621
    252
    Mar 25, 2018
    I use a 20 amp and haven't had a problem yet, but everything connected to it combined doesn't draw 20 amps. The 3 way fridge is wired directly to the battery with it's own 15 amp inline fuse, it draws between 9 and 10 amps.
  6. mstrbill
    mstrbill Active Member
    674
    141
    Mar 17, 2013
    Austin , Texas
    40A if you have a F/C PUP with Barker power lift.
  7. rabird
    6,476
    215
    TX
    max fuse size usually depends on wire size.
