Gonn a replace a.c. gasket.
Discussion in 'Heating / Cooling Systems' started by Dearley09, Jun 7, 2018.
  1. Dearley09
    Dearley09 New Member
    Apr 9, 2018
    This weekend I'm gonna replace my ac gasket. It seems to be leaking there when it rains and also the condensation leaks through it also, instead of running down roof. Sounds like bad gasket right? I saw someone made a picture frame to lift the a.c. off the roof more. Is that necessary? What should I do while the a.c. is off to prevent leaking?
  2. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    Just do the gig in one day! Any time spent covering the hole is better done putting the AC back in. It should be a fairly quick job.
  3. nineoaks2004
    6,819
    2,736
    Graceville, Florida
    The four bolts that hold the AC could have loosed up, to check pull inside cover off, there is
    a bolt in each corner, it they are not tightened down water will leak from the area where the AC meets the roof, if they are tight then a new gasket is in order. Not a hard job to change it
    but you will have to lift it up which means disconnecting the wires lining up over the 14"X 14" hole can be a booger, especially with a pup as you will have t raise it up to align with the hole.
  4. crackerJack
    crackerJack Well-Known Member
    1,113
    286
    Jan 6, 2014
    Scottsville, KY
    Gasket swap is not very complicated.
    Sometimes condensation leaking inside is from a stopped up drain hole.
  5. Dearley09
    Apr 9, 2018
    How do I find the drain hole?
  6. crackerJack
    1,113
    286
    Jan 6, 2014
    Scottsville, KY
    On tge exterior of my coleman mach, it’s on the bottom, near the side, in the middle. :)
