Half door thumb latch
Discussion in 'Miscellaneous Repairs & Maintenance' started by HouseofWards, Jun 5, 2019.
  1. HouseofWards
    HouseofWards New Member
    May 6, 2019
    Working on my NTM 200? Jayco Qwest 10x. The upper portion of the half door is kinda wonky and doesn't really fit correctly. However, watching a few videos, I'm noticing some people have a "thumb latch" that connects the upper half to the bottom half. Mine appears to be missing. As anyone found a replacement for this latch or know where I can find one?
  2. SteveP
    SteveP Well-Known Member
    1,240
    283
    A long time since I've had a 2 piece door, "kinda wonky and doesn't really fit correctly" is an apt description. I seem to remember that my old Starcraft had a small barrel bolt to connect the two pieces of the door but I don't remember if the frame had any connection or not.
  3. WrkrBee
    WrkrBee Well-Known Member
    1,731
    629
    Something like this?
    McMaster-Carr
    L-Handle Light Duty Turn-to-Open Draw Latches
    Use this L-handle latch to draw lightweight surfaces together.
    Brass-Plated Steel Dull 3/16" 2 5/8" 2 5/16" 7/8" Not Rated Yes 1561N12 $5.78
