Hand Pump Faucet won't turn off
Discussion in 'General Camping Discussion Forum' started by oldsca, Jul 24, 2015.
  1. oldsca
    oldsca New Member
    Mar 29, 2015
    Hello,
    I have a 1982 Bonair with a hand pump faucet. The hand pump works well however if I use the outside water hookup I can't turn the water off. If I turn the knob on top of the faucet the water pressure will increase or decrease but I can't turn the pressure completely off.
    Does anyone have any idea what my issue might be?
    Thank you.
    Wayne
  2. nineoaks2004
    6,819
    2,738
    Graceville, Florida
    You might need a new faucet...
  3. chuss
    chuss New Member
    23
    Aug 30, 2016
    Hello Wayne
    How did you resolve this faucet problem?
    I think I have a very similar issue.
  4. kitphantom
    11,554
    740
    @POPuPchuss
    the original poster (OP) hasn't been on the Portal since last July, so you aren't likely to get an answer from him.
    If you ask your own question about the problem, you should get better results. Here's an area to start: http://www.popupportal.com/index.php?board=59.0
    I can't help directly, since we never used the hand pump/city water type of faucets in our popups. (One was broken when we bought the pup, we didn't even try with the second pup, we removed the faucet as soon as we bought it, and covered the sink.)
  5. Halford
    Halford Well-Known Member
    3,557
    555
    Sep 28, 2011
    Santa Clarita, California
    I had a problem with my hand pump with Key West. I just simply replaced the hand pump... Yours may have been worn out by a lot of use...
  6. opie232
    opie232 Member
    283
    Mar 1, 2013
    Replace the faucet. Easy to do. I picked mine up on amazon fairly cheap.
