hanging lights on awning
Discussion in 'Lighting, Interior and Exterior' started by LockhartClan, May 8, 2012.
  1. LockhartClan
    LockhartClan New Member
    25
    Feb 5, 2012
    We just got a 2006 fleetwood wiliamsberg with an awning, the type with 3 legs attached they fold up. I picked up the light hooks before opening the awning, they are the style for the awning with the slot. So my questions is where and how do you hang your camper lights. I was thinking about drilling hols and hanging with S hooks? Is this OK?
    thanks
  2. candleems
    candleems New Member
    727
    Jul 12, 2006
    South Central PA
    Clothes pins.
  3. Tyreguy
    Tyreguy Member
    612
    Apr 8, 2012
    I just loop the lights around the horizontal poles and let em' dangle- picture a sloppy candy-cane scenario. No hooks, no ties. [:D]
  4. fritz_monroe
    fritz_monroe New Member
    1,310
    Jan 31, 2006
    I use small spring clips like this.
  5. dschlosser
    dschlosser New Member
    1,013
    Jan 29, 2008
    East Patchogue, NY
    Binder clips.
  6. Raycfe
    11,599
    X2 Binder clips from staples ..... lights, gismos ....... tarps .... good and strong hold well all different sizes.
  7. airmech2210
    airmech2210 New Member
    119
    Apr 15, 2011
    X3 for binder clips
  8. Dubbya
    6,135
    Aug 2, 2011
    I drilled a few 1/8" holes across the front bottom edge of my carefree awning, ran a 4" length of 16 gauge (black) insulated wire through each hole and twisted the ends together to hang the light string. Doesn't matter how windy it gets, the little wires hold the light string steady and I leave them in place so I don't lose them when I remove the light string and pack up the awning.
    "S" hooks would work fine too but they're markedly more difficult to bend if need be.
  9. nancyanddan
    nancyanddan Active Member
    1,495
    Dec 2, 2011
    X4 for binder clips!
  10. Starcraft Away
    Starcraft Away New Member
    853
    Feb 10, 2012
    binder Clips here , cheap easy and no work involved to install.
  11. mamabean5
    mamabean5 Active Member
    7,229
    Oct 7, 2009
    Used to use clothes pins until my DD majoring in Hospitality turned me on to Binder clips. They are great! The super large ones work wonderfully as tablecloth holders too. :)
  12. Halford
    Halford Well-Known Member
    can try the hooks for gutters that holds Christmas icicle lights
  13. Kdugan
    Kdugan Member
    311
    Jul 8, 2010
    Yep you guessed it... Binder clips [:D] they work great for lots of things!
  14. jash1178
    jash1178 You can't fix stupid!
    1,051
    Nov 21, 2010
    North Carolina
    I use the wire bread ties. And when taking them down to pack up, I just leave the bread ties on the awning, twist them tight, and leave them on the awning for next time. [CP]
  15. RotnMom
    RotnMom Am I there yet?
    4,226
    Apr 4, 2011
  16. mamabean5
    7,229
    Oct 7, 2009
  17. raymonk
    raymonk New Member
    475
    May 13, 2011
    Clothes pins but not the cheap plastic ones that you get a dozen for a dollar.These won't work well. We've also used those black report clips, I like to use the ones that are about 2 inches.
  18. Hawkester
    Hawkester Hawkesnest
    1,313
    May 23, 2008
    SE Wisconsin
    We use rope lights so the wrap around the top horizontal poles to the right and left and I use a "S" type hook to connect them back to themselves.
  19. raymonk
    raymonk New Member
    475
    May 13, 2011
    I like the rope light idea. Last year, I bought a set of patio lights, the kind with little round glass bulbs about 2" round, and found these a mess to work with as these were very fragile. I broke severa of the lights just trying to hang them. The patio lights that we all have grown to love or hate, aren't what they used to be, rather small. Rope lighting, now does this give off enough light?
