Harbor Freight WDH
Discussion in 'Tow Vehicles, Hitch & Towing' started by TexasRN, May 17, 2019 at 2:27 PM.
  1. TexasRN
    TexasRN New Member
    Apr 28, 2019
    Does anyone know if the WDH from Harbor Freight will work with a Coleman popup? The side mounted jack makes it difficult to find a WDH that works.
  2. kcsa75
    kcsa75 Well-Known Member
    2,286
    936
    Sep 9, 2013
    Kansas City
    I don't know if it will fit or not, but I would never trust a WDH from Harbor Freight.
    If you haven't already, you need to confirm that the frame on your pup will support a WDH.
  3. generok
    generok Well-Known Member
    2,350
    489
    Feb 7, 2013
    Anchorage, AK
    In general, I don't see how a side mounted jack will allow for attachment of the spring bar points on the tongue. You'd need to have a pretty long tongue, and then have the jack mounted pretty far back, and then swing away from the mounts... that's a lot of holes in the swiss cheese to align.
    I usually see center mount jacks when using a WDH.
    Also, check your tongue channels. If they are closed tube, you may be okay. If they are open or "C" channel, you're going to need to do some mods, including perhaps some welds, to make it all work okay... perhaps.
    I would be skeptical of a Harbor Freight WDH too. Just my [2C]
  4. BikeNFish
    BikeNFish Well-Known Member
    2,351
    1,355
    Apr 24, 2017
    Maplewood, MN
    Harbor Freight is good for stuff that you need in a pinch for cheap. They will never be accused of having high quality stuff. If you need something that is cheap and "good enough", go to Harbor Freight. If you want dependability and high quality, stay away.
    With that being said, I purchase stuff from Harbor Freight all the time, but with the idea of knowing that if it fails (and there is a higher probability that it will) it is to be expected and I got exactly what I paid for.
  5. tzmartin
    tzmartin Well-Known Member
    837
    279
    Sep 9, 2015
    You can have a side mounted jack and wdh. You need attach one side of your spring bars first, then lower the jack and swing it up. Then do the other springbar with your lever bar. I don't know about the HF wdh but if the springbar is about 5 inches below the tongue, you're good.
  6. Rusty2192
    Rusty2192 Active Member
    749
    240
    Jul 30, 2014
    Kentucky
    I’ve seen many people with travel trailers that are happy with the HF WDH. But, in addition to potential mounting issues, the real problem with it is that it comes only with 10,000 lb trailer /1,000 lb tongue weight spring bars, which are way too stiff for a pup and could potentially kink the tongue right off on a big enough dip. The bars need to be matched to the tongue weight of the trailer.
    This guy was using the HF WDH on an R-pod TT, and destroyed his tongue and nearly lost the whole trailer.
