heat while not on shore power
Discussion in 'Heating / Cooling Systems' started by Roncyr, Apr 30, 2018.
  1. Roncyr
    Roncyr New Member
    May 23, 2015
    New Brunswick, canada
    Hello Folks
    My furnace will not kick on while dry camping. I am assuming that it requires a spark to fire it up and it should be able to get this from my battery? I have a 2001 Coleman Sedona. I bought it used. My truck is 2010 F150. Battery was fully charged prior to leaving on camping trip. thanks for any help you can give.
    Cheers
    Ron
  2. BikeNFish
    BikeNFish Well-Known Member
    2,481
    1,448
    Apr 24, 2017
    Maplewood, MN
    My furnace runs on battery. Sounds like a sparking issue. Did you check the gas (lines and tank)?
    Sometimes my furnace needs a little TLC the first time I use it. I light the stove first to make sure the gas is working.
  3. Roncyr
    Roncyr New Member
    May 23, 2015
    Yessir, the cook top worked just fine so propane wasn't an issue. Furnace worked when I got back home and plugged back into shore power.
    Thanks for the reply
    maybe I should mention I don't have lights on battery power either... probably should added that
  4. BikeNFish
    2,481
    1,448
    Apr 24, 2017
    Maplewood, MN
    Have you checked the fuses?
  5. Roncyr
    Roncyr New Member
    May 23, 2015
    yup fuses ok, I looked a little deeper. I may have reversed the polarity when I hooked up the battery.
  6. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    This happens to many people. I put Red Duct tape on the positive cable Black electrical tape on the negative.
  7. Roncyr
    Roncyr New Member
    May 23, 2015
    good tip, thanks
  8. Raycfe
    14,404
    1,072
    And if you do connect the battery leads wrong you will blow the the battery fuse in the convertor. Double check those fuses again.
  9. Roncyr
    Roncyr New Member
    May 23, 2015
    will do, assume that fuse is located in the same 'panel' as the rest of the fuses?
