Help! 1997 Coleman Cheyenne ABS Repair
Discussion in 'Roof/Floor Repair & Maintenance' started by Stryker3232, Apr 23, 2018.
  1. Stryker3232
    Stryker3232 New Member
    Oct 23, 2017
    I think I understand what I need to do to fix the cracks (MEK/ABS) and bedliner on the top once repaired. Where I am struggling... missing pieces of ABS. I don't have the energy to completely remove the ABS so I would like to just fill in the missing spots before covering with bedliner. How do I do this? What products should I use?
    Thank you!
  2. HotelRoyale
    HotelRoyale Member
    89
    38
    Sep 23, 2016
    Use the same ABS "goo" you use to fill in the cracks to cover those areas where the ABS has flaked off. I used a 50/50 mix of MEK and airsoft pellets to make my goo, I used it to fill the cracks and replace a few missing flakes ... but mine was nowhere near as bad as yours! Ugh, that's a classic case of delamination ... are you using Grizzly Grip bedliner? It worked great for me.
  3. jnc
    I need to ask How long has it been sense you did your Roof and are there any issues now and is it stored indoors?
  4. Montyrob
    Montyrob Member
    58
    May 8, 2011
    Henrietta, NY
    I just bought UPOL Fiberal Lite to fill in the cracks and missing pieces, I'll let you know how it works
    Stryker3232 likes this.
  5. Stryker3232
    Oct 23, 2017
    Thanks HotelRoyale! In your opinion would it be easier to just remove the outer ABS shell and Grizzly over the fiberglass?
  6. ezakoske
    ezakoske Active Member
    462
    46
    Nov 30, 2014
    Escondido, CA
    I wouldn't even bother with the ABS goo and patching....That looks way too far gone for that.
    Strip off the ABS and coat it with Grizzly Grip, Raptor, or whatever your bedliner of choice is.
    It'll be well worth your effort vs. trying to save your current ABS.
    My $0.02
    Erik
  7. NYR774
    NYR774 New Member
    19
    Dec 28, 2016
    Western PA
    I just recently did this repair and I'm very happy with the results from completely removing the outer layer: http://www.popupportal.com/threads/grizzly-grip-roof-repair.117543/
    I was geared up for it to be a big process but the roof was so debonded it actually came off pretty quickly. Looking at your pictures I think a putty knife would make quick work of the roof removal.
    If you take any chunks of foam off with the roof you can fill in with bondo and then sand.
    It will be some work now but probably less then trying to fill everything in and I think the end result will be much better.
  8. Stryker3232
    Oct 23, 2017
    Thank you. I have started the abs removal process.
    LeighAnnD likes this.
  9. Stryker3232
    Oct 23, 2017
    Is the awning rail glued to the abs roof? Any tips for how to remove?
  10. NYR774
    NYR774 New Member
    19
    Dec 28, 2016
    Western PA
    My awning rail was both glued and riveted. I drilled out the rivets and then pulled the awning rail off with a putty knife.
  11. eagerbeaver
    eagerbeaver New Member
    Mar 29, 2018
    Would love to see pictures of the restoration under way. :) I agree, peel that abs
    Thanks
  12. jnc
    Any chance to see some progress?
  13. Firering
    Firering New Member
    19
    May 24, 2014
    St Louis
    Good luck with your project. Check out my YouTube video on my roof project. STLF1BAR is my channel.
    ezakoske likes this.
  14. Sjm9911
    1,992
    794
    How about a link?
  15. ezakoske
    462
    46
    Nov 30, 2014
    Escondido, CA
    I watched your series of vids on YouTube before embarking on my project - super helpful! Thanks so much for taking the time to make them!!
    Erik
  16. Stryker3232
    Oct 23, 2017
    Wow, I am super slow on this project. Here are a couple of pics. The first one is with the abs roof finally removed. The delaminated parts were easy, the others not so much. I started filling in the foam with Bondo tonight and placed my order for Grizzly grip.
    The second picture is an abs roof cap for the lift system. I have looked everywhere for the name of this part and can't find it anywhere. The curbside cap was a casualty of the removal process and I need to purchase one before putting on the grizzly grip. Can anyone help me with this? abs removal.jpg cover.jpg
  17. bols2Dawall
    bols2Dawall S.W. Ontario
    1,362
    100
    May 19, 2010
    Lasalle Ontario
    3D printer service ?
  18. jnc
    I was wondering if the cracks in the second photo with the post cover are just stains from the delamination?
