Help me figure my correct drop
Discussion in 'Tow Vehicles, Hitch & Towing' started by mpking, May 12, 2018.
  1. mpking
    mpking Well-Known Member
    1,065
    178
    Jun 17, 2014
    Raynham, MA
    So I have tow measurements.
    Ground to top of reciever on the TV is 17.5" unloaded, and 15.5" when the campers is on.
    With the camper leveled, the Bottom of the coupler is 15.".
    Here's where I'm having a mental math error.
    I'm assuming I subtract Coupler (15") from Loaded TV (15.5") giving me a drop of .5"-1.0"? (I'm not sure if I've seen a .5" drop, and a little nose down won't hurt)
    Did I do that right (Ignore the unloaded weight, since it drops almost 2 inches)
  2. jnc
    I think you will be fine with a 2" drop. I have never seen anything less than a 2" drop.
  3. Snow
    9,302
    599
    Would you not take the 17.5 height of the vehicle and subtract the height of the level trailer 15.5 ... which would give you a drop of two inches.. ?
    myride likes this.
  4. Fless
    Fless Active Member
    musicmuso12345 likes this.
  5. jnc
  6. mpking
    1,065
    178
    Jun 17, 2014
    Raynham, MA
    Ended up buying a 2 inch drop locally. Trailer looks level enough. It is nose down a bit, but that's not such a bad thing
    jnc and Fless like this.
