Help me identify replacement key type
Discussion in 'Campsite Security & Safety' started by mpking, Jun 14, 2016.
  1. mpking
    mpking Well-Known Member
    1,154
    237
    Jun 17, 2014
    Raynham, MA
    So the key's are gone, so I need replacements.
    This is off a 1995 Jayco
    Here's a picture of the lock, what kind of key is this? All the RVKey replacement sites reference codes 301-351'
    The writing says A115:
  2. Fuzzy Bear
    Fuzzy Bear Active Member
    493
    93
    Mar 3, 2004
    Norwalk CT
    I have a feeling the lock may have been replaced at some time. I looked up A115 in my code books and don't find a likely match for yours. If you don't have any luck finding a code key take it to your local locksmith. It is a fairly simple lock (from looking at it seems to be a wafer tumbler lock) and a new key can be made by impression by a knowledgeable locksmith.
  3. mpking
    1,154
    237
    Jun 17, 2014
    Raynham, MA
    I zoomed the image, and played with the contrast to try and make the numbers "pop" more.
    Now I'm not sure if it's A115, or A145.
  4. Strikeouthhh
    Strikeouthhh Member
    98
    Jun 11, 2015
    St. Paul
    I just did what fuzzy bear said - unscrewed it from the inside and took it to a locksmith- evidently no tumblers - the blank key worked!
    Granted with a pup it's more of nuisance lock than anything else, but still!
    PU - 1991 Viking SP175
    TV - 2010 VW TDi Sportswagon STICK
    "I drank What!?!" - Socrates.
  5. mpking
    1,154
    237
    Jun 17, 2014
    Raynham, MA
    Well,
    To my surprise, my coupler lock key fits and turns.. So I'm all set now.
  6. Strikeouthhh
    Strikeouthhh Member
    98
    Jun 11, 2015
    St. Paul
    There you go.
