Hitch ball loosening after each trip
Discussion in 'Tow Vehicles, Hitch & Towing' started by cdawson46, Aug 8, 2018.
  1. cdawson46
    cdawson46 New Member
    Jul 11, 2018
    So we just started using our new hitch with our 1996 Coleman cheyenne, and after our first trip I noticed the hitch ball had loosened enough so that I could turn it with my hand.
    So I got out the wrenches and tightened the heck out of it.
    We recently just went on a 5+ hour trip to northern Ontario and after getting back I noticed the same thing again, it's loosened up once more.
    I have yet to put grease on the ball due to budgetary reasons, but I am at a loss for how to stop this, as I tightened it about as much as I can physically tighten it myself.
    Will putting grease on the ball allow the trailer to not loosen the ball?
  2. BikeNFish
    BikeNFish Well-Known Member
    2,339
    1,346
    Apr 24, 2017
    Maplewood, MN
    Is there a lock washer being used between the nut and the ball mount? If not, that is your problem.
    If you don't have grease for the ball, you can use any lubricating material on the ball: WD-40, engine oil, vegetable oil, etc... until you can grease it.
    I use a squirt of WD-40 before each use because grease can get messy after a while.
    kcsa75, emoney and J Starsky like this.
  3. WrkrBee
    WrkrBee Well-Known Member
    1,497
    524
    Are you running out of threads on the ball stud? This will make if feel tight, when it is not. Take the nut off and add a washer, then a lock washer, then the nut. After that I drill a hole below the nut and add a split pin to prevent from losing the nut, if it gets loose.
    kcsa75 and Sjm9911 like this.
  4. Matt Benoit
    Matt Benoit Active Member
    410
    228
    Jul 30, 2017
    Warren, MI
    Grease will help. Also the draw bar may help... Most Reese drawbars have a recessed area that the ball fits perfectly into preventing it from turning. I also purchased the wrench that they sell specifically for the nut on the ball. It's the right size and longer than anything else I have. I believe it was $7 at Walmart. This allowed me to tighten the nut beyond any other means. Also, when tightening the nut, make sure that the draw bar is in the hitch. Don't try to do this in a vise or on a table. Use the weight of the vehicle to your advantage too keep the draw bar from moving.
  5. mattlreese
    mattlreese Active Member
    168
    44
    Sep 6, 2017
    Is the ball torqued to the required specs? Mine required 250 ft lbs which is a massive amount of torque. I did not have a torque wrench that went that high or a bit high enough so I had the dealer do it when I rented a popup a few years ago.
  6. J Starsky
    J Starsky Well-Known Member
    609
    369
    Aug 3, 2017
    East Central MN
    If you are not using two large pipe wrenches while leaning on them for all life, it's not tight enough! Great stuff from above, but you might consider lock-tite product to help you out as well.
  7. cdawson46
    Jul 11, 2018
    I bought the entire hitch system from uhaul, and I installed it as the instructions read.
    I think after reading everyone's comments, that I'm not able to get it tight enough on my own.
    Might have to go into the dealer that installed the hitch to get them to tighten it.
  8. cdawson46
    Jul 11, 2018
    I believe it does have one that came with it from uhaul.
  9. WrkrBee
    1,497
    524
    Make sure you have the right ball for the draw bar. Some balls have 3/4" and some 1" studs (I'll verify diameters later). A small stud in a big hole will allow for play and loosen nuts, also. Something about this sounds wrong, but minds out of the gutter.
  10. Customer
    Customer Well-Known Member
    2,433
    237
    Jun 5, 2014
    Tip for tightening; put the ball mount into the receiver turned 90 degrees from normal so you can push down while tightening. Put a socket and breaker bar on the nut and stand on it.
    erond, FarmerDave, friartuck and 6 others like this.
  11. nineoaks2004
    6,435
    2,428
    Graceville, Florida
    Also as mentioned if the stud is small and the hole is large, they do make a sleeve that will keep the ball from slipping, however it would be better to get the proper ball with the right size stud and also a lock washer will lock it down, I always use red locktite to make sure, I keep my ball greased and have a cover that goes over it when not used. If you cannot get it tight a garage with air tools can tighten it up for you reasonable. It could be dangerous and potentially deadly if the ball comes off while traveling. When I went from 2" ball to 2 1/4" they had to cut the 2" ball off, nothing they had a CW would remove it, after about 1/2 hour they finally asked if they could cut it off with a torch and I agreed.
  12. joet
    3,992
    671
    If the hole is the correct size for the shank on the ball... and if the nut is torqued to the proper spec. It won't come loose. Something is wrong somewhere. Just tightening the nut as tight as you can get it does not make it rite. Follow the torque spec that came with the ball,, ,use a torque wrench you can't guess
  13. jnc
    3,904
    1,145
    Oct 1, 2014
    South Central New Hampshire
    You can use the DW's Nail Polish for lock tite. Just ask her for one she dont like and she will give you your choice of color.
    friartuck and kcsa75 like this.
  14. MNTCamper
    MNTCamper Active Member
    748
    122
    Jun 14, 2014
    A proper lock washer will keep it from loosening for sure.
  15. Fbird
    Fbird Active Member
    262
    113
    Sep 10, 2017
    Ferndale MI
    Like others have said make sure the shank on the ball is the same for the drawbar. Make sure there is a lock washer, it's job is to make sure the nut stays tight. I know most everything has a torque spec but I have found the old German spec of gootentite works for this application. Do use the proper wrench or socket. If you don't think you can get it tight enough, take it to a mechanic you deal with. He'll probably do it for nothing. As a mechanic tips in these cases are appreciated[:D]
  16. emoney
    emoney Well-Known Member
    880
    443
    Jul 7, 2018
    I’m of the opinion that everyone that tows anything you should a “hitch ball wrench”. They carry them at Wally World for like $20 I think and fit a 2” or 1 7/8” balls. It’s probably 18”-20” long and allows you to get the proper amount of torque when tightening. This way you compress the lock washer and it can do it’s job. If it isn’t compressed then it’s just a regular washer and almost more of a spacer
  17. joet
    3,992
    671
    How can one determine the difference in torque between 150lbs and 350lbs with just a wrench?
    xxxapache likes this.
  18. WrkrBee
    1,497
    524
    If the hitch is turned 90 degrees in the receiver, I put the wrench on the nut, about level, and I stand on the wrench at 12" out, that's about 200 ft lbs. If I stand 24" out on the wrench, that's about 400 ft lbs.
    Customer likes this.
  19. joet
    3,992
    671
    The point is how can you be sure of the amount applied every time is the exact same..,you can't.
    you could be off by a hundred pounds. A good attorney at deposition would have a field day.
  20. Adam H
    Adam H Active Member
    336
    110
    Aug 22, 2015
    And how would an attorney know what it was torqued to? That's like the weight people fearing litigation at every turn, and i live in the litigation capital of the world.
    I do the same thing, hitch sideways, 30" bar, soaked in red locktite and jump up and down until the bar stops moving. Unless the shank breaks off, it doesn't matter at that point if it's 200 lb/ft or 400 lb/ft. Never had one come loose.
    Adam
    Customer, myride and xxxapache like this.
