Hot water heater
Discussion in 'Heating / Cooling Systems' started by Whopper14, Sep 2, 2018.
  1. Whopper14
    Whopper14 Member
    38
    Jun 20, 2017
    Holland Mi
    Not working, propane and fuses ok. Red light comes on and stays on, no hot water. Was working earlier this trip, stopped last night. I am at brother in-laws house using his power, related? Any suggestions?
  2. NMroamer
    NMroamer Active Member
    433
    193
    Apr 21, 2016
    Albuquerque NM
    The red light should go out after a few seconds. Check that the pilot light is light. Thermocouple might have gone bad.
  3. emoney
    emoney Well-Known Member
    880
    447
    Jul 7, 2018
    Out of curiosity is there a manual option for light the pilot?
  4. theseus
    theseus Centerville, OH
    2,764
    364
    Feb 6, 2007
    Centerville, OH
    My guess is that you have a DSI model with no pilot light. That's what the red light is about. I don't know of any with a light that aren't DSI models. But I've been wrong before...
    Check for loose wires on the outside of the unit. Also check the over temp resets. They will prevent the unit from lighting.
  5. xxxapache
    2,702
    727
    If it is a DSI unit, it likely has a fuseable link that can go bad....Is it arcing and trying to light? If so, light a stove eye for a minute or two and try again.
  6. Whopper14
    Whopper14 Member
    38
    Jun 20, 2017
    Holland Mi
    Not trying to light, red light comes on and stays on. Will check for loose wires. Where would a durable link be found? Could it be thermocouple? Has been working fine.
  7. xxxapache
    2,702
    727
  8. Whopper14
    Whopper14 Member
    38
    Jun 20, 2017
    Holland Mi
    Ok, cleaned igniter and heater fires for about 10-15 sec and shuts off. Could the controller board be bad? This is a Suburban SW6D DSI model.
  9. theseus
    2,764
    364
    Feb 6, 2007
    Centerville, OH
    Maybe. I've had two Sw6de units, but have never experienced a controller going bad.
  10. Sjm9911
    3,315
    1,548
    Does it have a therocoupler? On any gas appliance , if it's getting gas, and not staying lit that's where I would look.
  11. Whopper14
    Whopper14 Member
    38
    Jun 20, 2017
    Holland Mi
    It was the ignition module PCB.
