How do you turn on the heater??? 2009 Viking Epic 1706
Discussion in 'Heating / Cooling Systems' started by Judyr, Apr 15, 2018.
  1. Judyr
    Judyr New Member
    Feb 18, 2018
    Pilot is lit. How do you turn the heater on? Is it the thermostat control under the table? We just bought used...no manual.
  2. BikeNFish
    BikeNFish Well-Known Member
    2,460
    1,441
    Apr 24, 2017
    Maplewood, MN
    I could be wrong, but the furnace shouldn't run on a pilot light. The water heater and the fridge will, but not the furnace. The furnace should turn on when you turn on the thermostat.
  3. BikeNFish
    2,460
    1,441
    Apr 24, 2017
    Maplewood, MN
    HERE is a Viking manual from 2003. Maybe that will help you
  4. Antipodes
    Antipodes Call me Paul
    772
    75
    Jan 28, 2015
    Christchurch, New Zealand
    2009 will not have pilot lit furnace. It will be electronic!
    You will have lit the water heater and I hope you have filled it with water correctly as it may be permanently damaged if you have not.
    The furnace will run when you have power to the trailer and if not shore power, then a good charged battery.
    The thermostat only needs to be move to the hotter position to get the furnace to automatically start.
    However if it is an Atwood furnace and thermostat, it may have a very small switch (Either on the top or bottom) of the thermostat, which can take a lot of force to switch on.
    The portal is full of this similar type of problems. So search will also give you more information.
    I suggest you also find out what make and model of Furnace you have, so that you can download the respective manual for that appliance. (Take the grill of the front, should give enough viewing space to read the info required)
    Manuals for campers and appliances are under the resources tab at the top.
  5. theseus
    theseus Centerville, OH
    2,758
    362
    Feb 6, 2007
    Centerville, OH
    Yes a 2009 will have a direct spark ignition for the furnace. As for the water heater, if that is what you lit, there will be thermal resets on the outside. They cut off the burner to prevent damage. You could have also lit the refrigerator pilot.
    Antipodes is right. You will have to have power either AC or DC. If you have a Suburban thermostat, move the temp lever to the right.
    If you have an Atwood thermostat, the switch to turn on the unit is typically under the bottom of the thermostat. Turn it on, then set the temp lever.
