How to check Battery Fluid level
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by mpking, Mar 14, 2018.
  1. mpking
    mpking Active Member
    Jun 17, 2014
    Raynham, MA
    I've seen people from time to time say check the electrolyte level in the battery.
    I've had my battery for almost 2 years. I have no idea how to do that. I've found stuff online that says just look and see if you need to add distilled water.
    Here's a photo of my battery... Thoughts?
  2. crackerJack
    crackerJack Active Member
    Jan 6, 2014
    Scottsville, KY
    Not sure about yours. Some batteries do not require water. What is the make and model?
    My 6v US battery 2200xc batteries have easy access caps. Most auto parts stores will have a filler, which looks like a turkey baster.
  3. Raycfe
    The level is to the bottom edge of the "tunnel/tube" you are looking at. Just add enough to come up to the bottom of the tubes. The fiuld should aways cover the fins/plates of the battery. Don't overfill as it will make a mess in your battery box.
    jnc likes this.
  4. BikeNFish
    BikeNFish Well-Known Member
    Apr 24, 2017
    Maplewood, MN
    This video is a quick tutorial on battery maintenance:
  5. f5moab
    May 7, 2013
    Somewhere in Idaho
    Get one of these and check the specific gravity too....
    Called a Hydrometer....
  6. joet
    Never add water to a discharged battery. When you charge it, the electrolyte heats and expands. I have seen it overflow and run out. Always add water to a fully charged battery.
