I got new tires...question
Discussion in 'Tires / Brakes / Bearings / Axles' started by jmkay1, Aug 20, 2018.
  1. jmkay1
    3,722
    804
    I just got my tires replaced however I noticed there is a slight difference in the numbers from what I used to have. So not sure if it means anything. So here goes... Apparently my Goodyear marathon tires were well over 8 years and more than needed to be replaced. Those tires were st185/80R13 load range C radials. So the shop replaced them with...Cralisle 175/80r13 load range c radials. My question is regarding the 175 vrs 185 number? What is the difference? I did not feel any difference in the towing aspect, then again rush hour traffic is really not a good test. Also does anyone know how good Cralisle tires are? I never heard of them before, I would have preferred Goodyear but I was desperate for tires and it's what the shop had in stock. I was planning a last minute trip, as usual, and needed those tires replaced quick.
  2. Sjm9911
    1,992
    794
    The first number is the with of the tire, I don't know how it will affect the towing. Probubly not much. There is not a great deal of stock when it comes to tires, I think I got the 185s in a d range and had very few to pick from on the net. All tires I saw have good and bad ratings, but I think I bought the same brand as you. So I hope there good!
  3. chambo
    chambo Active Member
    352
    106
    Apr 27, 2015
    Southern California
    The first number is the tire width measured from sidewall to sidewall. So your new tires are 10mm skinnier than your old tires. I'm not enough of a tire expert to know what the trade offs are. I would guess that a skinnier tire will have less resistance for towing, but also have less surface area touching the road when stopping. I doubt any of this will really matter in a trailer.
  4. MrsSquid
    MrsSquid Active Member
    292
    94
    Aug 31, 2016
    Virginia
    Hi jmkay1,
    Good to hear you got new tires.
    I asked MrSquid to answer your question so here it is:
    Hope that helps.
  5. SteveP
    SteveP Well-Known Member
    1,072
    213
    The 175s will probably have a slightly lower load rating than the 185s.
  6. Snow
    9,303
    602
    Take them back and get the proper size.. each tire size has a different load range. Most st185/80R13 with LR "c" can support a weight of 1725lbs each. Those new ones you got can only do a weight of 1360lbs each. That's a 730lb difference for the pair..
    xxxapache and Raycfe like this.
  7. Raycfe
    13,887
    920
    I would take them back also.
  8. Sjm9911
    1,992
    794
    The load range isn't universal? Really?
  9. Sjm9911
    1,992
    794
    Looked it up and the ranges are diffrent. I guess that's why it's a range. Befo re jumping the gun and taking them back I would check on the weight of the trailor.
  10. Snow
    9,303
    602
    The GVWR is 3620lbs according to the 2004 brochure..
  11. Sjm9911
    1,992
    794
    Ouch , just saw that in his profile. I have d loads on mine. Simmiler pup, older.
  12. joet
    3,561
    515
    TAKE THEM BACK!
  13. jmkay1
    3,722
    804
    Thanks all for your help. I called the shop and he will replace them. However we mentioned that even my old tires were too small for the weight of my camper. He is going to try and see if another size will fit in my wheel well. If anyone has a fleetwood Utah do you know what size tires you have? I'm going to do some research as well as I'm very nervous about this now.
    MrsSquid likes this.
  14. Halford
    Halford Well-Known Member
    3,440
    439
    Sep 28, 2011
    Santa Clarita, California
    I have Marathon ST185/80R13 for mine.
  15. SteveP
    1,072
    213
    The only 185/80R13s I can find in load range C are by Maxxis, with a load range of 1480# at 50 psi. This should be enough for a 3700# pup as you should have at least 350# on the tongue. Load range D, which is more common in this size, would be even better but would require higher pressure.
  16. jmkay1
    3,722
    804
    Is that a load range C? The load range C shows 1480 pound rating and my camper is 3600 pounds. Even the C's I had on didn't get me to that #. Or am I looking at it wrong?
  17. Halford
    3,440
    439
    Sep 28, 2011
    Yes the Range C on my Marathon. I just found out that my Niagara GVRW is 3350 lbs, not the 3500 as I thought. The Load C is perfect for my Niagara.
  18. Snow
    9,303
    602
    You may have to look at Kenda Loadstar bias tires with 1725lb for their load range "c". Tires.
  19. myride
    myride Well-Known Member
    749
    320
    May 14, 2015
    Edmonton, AB
    I run ST185/80R13 "D" by Carlisle on mine...which is the same trailer as yourself.
