I need furnace advice!
Discussion in 'Heating / Cooling Systems' started by Kevin Jessee, Oct 14, 2018.
  1. Kevin Jessee
    Kevin Jessee New Member
    Aug 1, 2017
    Meridian, Idaho
    F232E9D8-E60B-4C05-8B93-0B205774975A.jpeg 1A208B87-2F36-466F-BC8F-105FE0F38D26.jpeg
    i have a 98 Coleman Seapine that has an Atwood 7916-II that I’m trying to replace the blower motor on. Problem is, I suck at this stuff and I can’t figure out how to get the motor out. I removed the Allen screw, but it won’t come off the fan wheel. I just can’t get the end off. Can someone help understand how this sucker comes off? Are the two holes in the bottom for hidden screws?
  2. tombiasi
    4,952
    716
    See if there is a set screw or two holding the shaft. If not it may be pressed on.
  3. Kevin Jessee
    Aug 1, 2017
    Meridian, Idaho
    Thanks for the reply. I took out the only 2 set screws I can see.
  4. Kevin Jessee
    Aug 1, 2017
    Meridian, Idaho
    It would help if I could find a good manual with all the details.
  5. rabird
    6,476
    217
    TX
    can ya hang onto the shaft on the other side and try and spin the combustion wheel?
  6. WrkrBee
    WrkrBee Well-Known Member
    1,727
    628
    The two holes are probably for a wheel puller. The puller has a jack screw in the center, and slots on both sides for the pulling screws. The two holes may be tapped, but may be just there to tap, if needed.
    xxxapache likes this.
  7. Raycfe
    14,381
    1,069
    I would soak it with wd40, etc then support the backside of the fan on some wooden blocks and then tap the shaft in the center of the fan with a small punch/rod/bolt to free it up and drive the shaft out of the fan.
    jnc likes this.
  8. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    Raycfe has the idea of what needs doing. You could try to have someone applying pressure on the back of the fan with a pry bar while you are tapping the shaft.
  9. BillyMc
    BillyMc Well-Known Member
    621
    252
    Mar 25, 2018
    Looks a lot like an older model automotive blower. Those had a set screw on the flat side of the shaft. Over time they would sometimes become seized to the shaft. applying penetrating oil or heat can help free it.
  10. tenttrailer
    3,078
    252
    Jul 18, 2013
    Thornville, OH
    As others have mentioned. I would do both the wd40 down the shaft let it sit for awhile then do the, have someone hold the fan and tap with a punch light hammer. only on the shaft, light taps. You don't want the tapping to upset the motor.
  11. Sjm9911
    3,310
    1,544
    Penetrating oil works better then wd 40. Just fyi. Otherwise everyone is right on the money.
  12. theseus
    theseus Centerville, OH
    2,758
    362
    Feb 6, 2007
    Centerville, OH
