Indoor to outdoor shower mod?
Discussion in 'General Camping Discussion Forum' started by p, May 6, 2017.
  1. p
    p Active Member
    491
    99
    Jun 9, 2014
    can I connect a hose to our sink tap and run a shower wand to the outside? We have a hot water tank and the shower would be great...even a spritz is better then nothing.
  2. xxxapache
    2,740
    759
    Don't see why not
  3. p
    p Active Member
    491
    99
    Jun 9, 2014
    But... how connect the hose to the tap?
  4. xxxapache
    2,740
    759
    Not a clue....i don't know what you have.
  5. Snow
    9,831
    848
    There are a number of mods where folks have done this sort of thing. .
  6. mstrbill
    mstrbill Active Member
    688
    144
    Mar 17, 2013
    Austin , Texas
    I would consider adding a Hot & Cold Spray Port, then you don't have to worry about running a hose thru the tenting
    Spray Port
  7. p
    p Active Member
    491
    99
    Jun 9, 2014
    Simple is better for me. A shower wand that I can attach and extend through a flap to the outside and I yell back to the person on the inside...too hot...too cold...etc.
    The plastic rock wood tap will not allow a screw on hose.
  8. crackerJack
    crackerJack Well-Known Member
    1,113
    286
    Jan 6, 2014
    Scottsville, KY
    The outlet of your faucet is called an aerator. Depending on the brand you can find a garden hose adapter.
  9. Rusty2192
    Rusty2192 Well-Known Member
    802
    289
    Jul 30, 2014
    Kentucky
  10. sierrapup
    sierrapup Active Member
    373
    38
    Jun 19, 2016
    or check out the big kahuna portable shower...works great
  11. Mongo71
    Mongo71 Longwood FL
    76
    Nov 4, 2007
    Central Florida
    One of the first modifications I did on my '97 StarCraft Venture was to put in an outdoor shower and single point hot water heater. Likely as not, you can find the shower kit at your local RV dealer. I was fortunate that I could cut into the side of my camper right behind the indoor sink. Originally, I just teed into the cold water pex piping and Q-pex fittings. Later, when I re-plumbed with PVC, I just used fittings from the local hardware store. Looks and acts like factory installed. HTH
  12. Zephyr
    Zephyr Active Member
    273
    40
    Jun 18, 2013
    central Oregon
    I like the simplicity of the hose through the canvas method. Once you get the temperature adjusted, you can have the person inside just turn the water pump off while you soap up and back on to rinse.....saves on water and you don't have to go through the water temperature dance again.
