Info for Dutch Oven cooking
Discussion in 'I Smell Something Cooking!' started by nineoaks2004, Aug 17, 2018.
Tags:
  1. nineoaks2004
    6,018
    2,210
    Graceville, Florida
    The chart provided here tells how many charcoal briquettes to use when cooking in your Dutch oven, for the size oven you have chosen to use. You can, of course, cook using the coals of your campfire, and by using this chart, you can also get a good idea how many coals to use as well.
    Lodge Manufacturing recommends that you use the "3 up, 3 down = 325 degrees F" formula. This formula is based on the oven's diameter and the use of full-size charcoal briquettes. The diameter plus 3 equals the number of briquettes required for top heat. The diameter minus 3 equals the number of briquettes needed for bottom heat. This heats the oven to 325 degrees F.
    Oven Sizes 5 inch 8 inch 10 inch 12 inch 14 inch 16 inch
    Top Heat 8 11 13 15 17 19
    Bottom Heat 3 5 7 9 11 13
    gatorbait likes this.
  2. jmkay1
    3,919
    919
    Actually good to have, never realized it was by threes. I cheated and found a free Dutch oven calculator app for my phone. Plug in a little info and up pops the amount of charcoal you need. The way I look at it. My recipe is already on the phone so why not. ;) .Well except for the obvious when the phone dies.
  3. nineoaks2004
    6,018
    2,210
    Graceville, Florida
    I have used that chart for a long time and used to give it out when I taught the camp cooking course.
  4. Fless
    Fless Active Member
    891
    162
    Aug 14, 2012
    Colorful Colorado - the Centennial State
    So is there also a general formula to increase the temp? For example, how many additional coals to raise the temp to 375°?
  5. nineoaks2004
    6,018
    2,210
    Graceville, Florida
    Figure that each briquet will give about 30 deg. Temp. But will depend on the size of the DO.
  6. Sotovoce
    Sotovoce Active Member
    191
    72
    Jun 27, 2015
    Georgia
    Back in the dark ages (before smart phones) when I was a scout leader, we used a rule of thumb:
    2 x the diameter of the dutch oven with 2/3 on top and 1/3 on bottom.
    It worked well for my 10" oven, but would result in more coals on top and fewer on bottom than the Lodge formula. In my experience the oven baked at about 325* with this formula, which would agree with Lodge.
    Outside temperatures and wind will affect the number of coals needed. The harder, more expensive charcoal will provide a longer steady heat source, but we usually had the cheap stuff.
    BelchFire and Byrd_Huntr like this.
  7. hvac1877
    hvac1877 Old Dominion Iron Chefs Highland Springs, Va
    2,879
    41
    Mar 10, 2008
    Highland Springs Va
    take your dutch oven double the size that is the amount of briquets you need to get it to 350 F. each coal was 15 to 20 F. When starting charcoal in a chimney starter once the smoke goes from blue to clear your charcoal is ready. do not let them ash over you then have lost half your cooking time.
  8. Sjm9911
    2,364
    902
    Very good stuff, never used the Dutch oven outside the stove in my house. Too much new stuff to try out and not enough time!
  9. Sjm9911
    2,364
    902
  10. Sotovoce
    191
    72
    Jun 27, 2015
    Georgia
    Thanks Peter or Amy, we probably got less than 350* because of outdoor conditions and the cheap charcoal. The 15-20 F is pretty much in line with what I had seen. "Use 2-3 coals for each 25*" I need a real charcoal chimney. We've only had adapted #10 cans. They work, but a chimney would be better.
    I went to your olddominionchefs website. There's a lot of good information there. My scouts were always baking, so the 2/3 on top and 1/3 on bottom makes sense.
  11. hvac1877
    2,879
    41
    Mar 10, 2008
    Highland Springs Va
    If you live in Georgia some friends of mine are getting a dutch oven group going in Ga. here is the link to the event.
    https://www.facebook.com/events/1812718115486273/
  12. Sotovoce
    191
    72
    Jun 27, 2015
    Georgia
    I got the message that the link was not available.
  13. hvac1877
    2,879
    41
    Mar 10, 2008
    Highland Springs Va
    October 12 – October 14
    Oct 12 at 6 PM to Oct 14 at 12 PM
  14. Sotovoce
    191
    72
    Jun 27, 2015
    Georgia
    The Peach State Dutch Oven Group is private, which I like. I have made a request to join, but have not received a response yet.
    That October weekend is a choice time for camping rallies and weddings. Of the four events we have to choose from, the one at Black Rock Mountain would be the easiest to attend. Unfortunately, we'll have to set our sights on the next Peach State Dutch Oven gathering.
