Installing A/C unit
Discussion in 'Heating / Cooling Systems' started by Adam Metoxen, Sep 6, 2018.
  1. Adam Metoxen
    Adam Metoxen New Member
    Aug 14, 2018
    It's done. Thanks for the ideas. One more thing. What amp cord should I use?
  2. emoney
    emoney Well-Known Member
    880
    448
    Jul 7, 2018
    20 amp, if you’re asking about for the AC unit itself. Needs it’s own circuit in the converter also
    Orchid likes this.
  3. Raycfe
    14,526
    1,116
    Now that wasn't a bad job .....was it?
  4. Adam Metoxen
    Aug 14, 2018
    I'm plugging it in the outlet next to the converter. Do I still need a 20amp cord?
  5. emoney
    880
    448
    Jul 7, 2018
    It should have come wired with a 20 amp plug so if that’s what the receptacle is then it was dedicated for it. You still need to make sure you’ve got a 20 amp circuit. It will run on 15amp but you can damage the unit by doing so.
  6. Adam Metoxen
    Aug 14, 2018
    Mine did not come with a cord
  7. Orchid
    Orchid Sharp Shootin' Grandma
    5,118
    1,783
    May 8, 2011
    Florida by way of WV and MD
    When I replaced the cord on mine, I bought this. Because it runs across the ceiling and then just hangs inside the camper, I wanted the extra insulation around it, as opposed to just buying regular wiring. You may be able to buy this extra insulated type wire in a hardware store and then just wire on the plug, but I couldn't find it.
  8. emoney
    880
    448
    Jul 7, 2018
    Usually the plug for the AC is found under the dinette bear the converter. It’s a sideways prong plus which won’t allow you to plug into a standar outlet. You can pick the outlet up at HD or Lowe’s. But it will need to be installed into that 20 amp circuit. If you do already have that, you may already have the outlet?
  9. Nasteff
    Nasteff New Member
    25
    May 7, 2018
    Looks nice, any pics of the install process?
  10. Trvmtchll
    Trvmtchll New Member
    Aug 4, 2016
    So your saying if I have a roof vent in my camper it has built in brace? I’m looking to install AC on my 1999 JAYCO Eagle 12SO
  11. Raycfe
    14,526
    1,116
    Yep.... If you have a 14x14 vent..... put it in the hole and plug it in.
