Is my thermostat bad?
Discussion in 'Heating / Cooling Systems' started by Mike Gephart, Mar 24, 2019.
  1. Mike Gephart
    Mike Gephart New Member
    Mar 24, 2019
    Our maiden trip the heater turns on blows hot but doesnt seem to come back on. Last night while camping i only heard it come on once at it definetely got down below to where i had the thermostat set to. Any ideas?
    Thank you
  2. nineoaks2004
    6,819
    2,734
    Graceville, Florida
    Do you have the old type analog thermostat ? If so you can upgrade to a digital thermostat for less than $20.00 (Wally World is where I got mine) the digital makes a big difference and is more accurate that the old analog,
  3. Mike Gephart
    Mar 24, 2019
    0FD4AB28-0085-43C0-8FFC-8E04325BE42E.jpeg FBCBA85E-42D5-45A4-AEEF-17A5935A3DB4.jpeg Yes its analog ill take a picture
  4. Mike Gephart
    Mar 24, 2019
    Is the inside setting with longer cycles set wrong?
  5. Mike Gephart
    Mar 24, 2019
    Do you have a link to the wally world digital thermostats?
  6. nineoaks2004
    6,819
    2,734
    Graceville, Florida
    You would be happier with a new one. (My Opinion) I rarely use my furnace because I do not usually boondock and have elec, then I use the ceramic heater
    Mike Gephart likes this.
  7. Mike Gephart
    Mar 24, 2019
    Is the ceramic heater a portable one?
  8. nineoaks2004
    6,819
    2,734
    Graceville, Florida
    Yes, I keep one in my TT. I used to keep 2 in the PUP but dropped down to only one as the ceramic heaters got the unit to hot, they cost about $20.00 at most places and take up very little room.
  9. Mike Gephart
    Mar 24, 2019
    Nice ill Take a look at that. Ill probbaly try adjusting the aticipator lower and see if that works if not ill Buy one of the digital ones at wally world. Sounds like i should also pick up one those cermaic heaters to have on hand too
  10. PopUpSteve
    PopUpSteve Administrator
    18,546
    1,394
    Dec 22, 2002
    Malvern, PA
    What model # did you get?
  11. Mike Gephart
    Mar 24, 2019
    Yes please tell what model number
  12. nineoaks2004
    6,819
    2,734
    Graceville, Florida
    Honeywell Digital at Wally World cost was $17.00, only need to hook up 2 wires to replace, uses 2 AAA batteries in the TStat
  13. Mike Gephart
    Mar 24, 2019
  14. daveo1289
    daveo1289 Active Member
    956
    62
    Apr 24, 2012
    Rochester NY
    I did the t-stat change and loved it. Keeps the unit at a constant temp better than the analog t-stat.
