Is there a cap to fit two grey water hoses to in park with hookups?
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by LaRita Hughes, Apr 2, 2018.
  1. LaRita Hughes
    LaRita Hughes New Member
    Mar 20, 2018
    We will be staying in park with hookups and just wondering if I can drain both grey water(shower and sink) into sewer hose? Would be nice to hook it up and not worry about it? Im looking for cap with two hose openings if they make them?
  2. crackerJack
    crackerJack Well-Known Member
    1,043
    231
    Jan 6, 2014
    Scottsville, KY
    I am not aware of a “cap”.
    That is a common issue. There are numerous threads on here with several different options.
    1) Permanently tie the plumbing together under the camper and make one connection during setup to the site sewer with flex hose.
    2) During each setup tie the two lines together with flex hose and connect to the site sewer.
    1 1/2” sump pump hose, 1 1/2” barbed fittings, adapters, and hose clamps can be found readily at hardware stores.
