JUGS-Water Ones That Is
Discussion in 'First Time & New Camper Owners' started by Ashley Hancock, Jul 12, 2018.
  1. Ashley Hancock
    Ashley Hancock New Member
    23
    Jul 12, 2018
    We are redoing a 1996 Coleman Fleetwood Taos, it has a pump sink we are sticking with because we like suffering. We need a new water jug for it as the old one is original and filled with orange grime. Do we need something special to work with the pump sink?
    Would this work?
    https://www.amazon.com/dp/B000MTI0GA/ref=sspa_dk_detail_14?psc=1&pd_rd_i=B000MTI0GA
    Dan from Troup likes this.
  2. joet
    3,489
    493
    Don't see why it wouldn't work. You jus want to be able to secure it when traveling to prevent spillage
  3. silvermickey2002
    4,282
    196
    Sep 11, 2008
    Morris County, NJ
    I assume you placing it where the old one is. If so, as long as it fits then do it. As Joet stated above, just make sure to secure it. Also remember to clean and sanitize it before you use it. Also remember to let it dry out after a trip.
  4. J Starsky
    J Starsky Well-Known Member
    512
    290
    Aug 3, 2017
    East Central MN
    Click bait brought me in, turns out I'm a sucker for puns. Piers Anthony might be an old high school influence, but I'm not all super Scifi. Worth a read if you're looking for a good old book, folks.
    I've used jugs of all types as water storage. So long as you cleaned and sanitized them, whatever holds water. My dad keeps gallons in those old huge tide bottles. They have a nice spout for cleaning / dumping water and since they are Tide they must be clean.... I'd bet he drinks out of them, too [?:~{]
    You can find old 5 gallon jugs from some Asian food places. I keep drain oil in a free one from the place in town but would make a nice water jug. https://www.amazon.com/dp/B01N5QBIY...&pd_rd_r=7c43e56b-85d6-11e8-914f-9f4b0c666b45
    WVhillbilly likes this.
  5. Dan from Troup
    747
    393
    Apr 25, 2018
    Troup, Texas
    Funny title. [RTM]
  6. Raycfe
    13,811
    893
    Just remember that a tube for the hose thats fit thru the cap needs to go all the way to bottom.
    J Starsky likes this.
  7. J Starsky
    512
    290
    Aug 3, 2017
    East Central MN
    Zip tie a weight to it - old plastic spoon? I'd done that running syphons from can to can before. Hot, Juggy tip, Ray!
  8. sceri
    sceri Active Member
    112
    57
    Jun 1, 2018
    Washington State
    If the "JUGGS" were filled with orange grime, I'd look to replace the lines as well....
  9. myride
    myride Well-Known Member
    751
    322
    May 14, 2015
    Edmonton, AB
    Can't speak to the "Juggs" ...well I could BUT...welcome to the PUP from a fellow photog north of the 4th.
  10. tfischer
    tfischer Well-Known Member
    "Orange grime" is probably just rust/minerals from the water. Not pretty, but not bad for you either.
  11. Ashley Hancock
    23
    Jul 12, 2018
    So the pump sink will work with any water container then? How do you recommend securing it?
  12. nineoaks2004
    5,496
    1,853
    Graceville, Florida
    One other thing to make sure of is that the pickup hose is sealed where the hose goes into cap of the jug, if it leaks you could have a problem and at the very least lose your water.
  13. generok
    generok Well-Known Member
    2,199
    369
    Feb 7, 2013
    Anchorage, AK
  14. jnc
    You can get creative like 2 eye hooks and a ratchet strap, a box that it fits in snug or use the metal strapping that @generok linked to build a holding rack. I dont recommend using Bungee cords because they move to much.
  15. J Starsky
    512
    290
    Aug 3, 2017
    East Central MN
    Strap steel could be the best and cheap idea. You'll find it in your local hardware store. Not hard to remove either.
    https://goo.gl/images/yxa5Wf
  16. sceri
    sceri Active Member
    112
    57
    Jun 1, 2018
    Washington State
    Maybe so, but I still wouldn't want to drink from it; especially if I didn't have too....
  17. Shaman1
    Shaman1 Well-Known Member
    1,272
    140
    May 13, 2011
    Oklahoma City, Oklahoma
  18. MyName
    MyName Active Member
    159
    35
    Jan 12, 2018
    Ca
    If this sink is going to provide drinking water don't you need to make sure the jug is safe for food products (human consumption) ? That septic jug may leak chemicals into your water.
    Edit. Its a scepter not septic jug, I miss read the amazon link. My first question still stands.
    Ashley Hancock likes this.
  19. Ashley Hancock
    23
    Jul 12, 2018
    Great point. I think I will probably just bring bottles of water. So the sink will be washing hands and rinsing things off. Which I do guess still qualifies.
  20. TDS-MN
    TDS-MN Active Member
    451
    37
    Sep 29, 2013
    Minneapolis, MN
    IF you have the height to fit that style of jug for water, I agree there is no reason that it shouldn't work. The original jug that came with mine is much 'flatter' and has a larger footprint, so it does not really need to be secured into place, the weight of the water itself holds it. It just sits on the floor in the cabinet that houses the sink, directly above. We use our on-board water only for hand wash and preliminary rinsing of items like you stated above. Bottled water for drinking/coffee if needed.
    One thing I found with my setup, if the hose to the pump has any bends/kinks, it does not draw as well from the jug.
