Laminate floor
Discussion in 'General Camping Discussion Forum' started by opie232, Jan 28, 2017.
  1. opie232
    opie232 Member
    283
    Mar 1, 2013
    Curious to what others have used for laminate hardwood flooring in the pup. Did you lay it directly over the old vinyl or did you pull it up. Thinking of replacing the floor this spring.
  2. cyclop5
    cyclop5 Member
    104
    Jun 18, 2015
    we went with peel and stick flooring ,and put it over the old linoleum. So far, so good. It's lasted one season so far, with no issues.
  3. Orchid
    Orchid Sharp Shootin' Grandma
    5,125
    1,793
    May 8, 2011
    Florida by way of WV and MD
    Save yourself a lot of work and headache and lay it right over top the old stuff. That's what we have always done in the past.
    This time, we pulled up the old vinyl due to having to fix some spots in the floor, and the laying of new peel and stick was a big pain. It didn't want to stick to the old wood.
  4. MrsSquid
    MrsSquid Active Member
    307
    104
    Aug 31, 2016
    Virginia
    We pulled the old vinyl off. It was already loose in the corners under the cabinets. Those spots turned out to be where we some subfloor issues that had to be fixed first. Then we pulled out all the cabinets and dinette.
    We had originally planned on peel & stick planking. However, once the old vinyl was off, as Orchid noted, the subfloor was a bit more uneven with a little glue here and there. So, we opted for the pricier floating vinyl.
    It looks great, but boy was it a bigger project than we anticipated.
