Leak in the Regulator
Discussion in 'Propane - Got Gas' started by PopUpSteve, Jun 1, 2019.
  1. PopUpSteve
    PopUpSteve Administrator
    18,546
    1,394
    Dec 22, 2002
    Malvern, PA
    While a driving down a wooded back road on my way to the Vermont rally last year, I heard a bang of something hitting metal. I pulled over and found one of those large round nuts (larger than a golf ball but smaller than a baseball) lodged between my propane tanks. I didn't think much of it but later on my trip, when I switched from one tank to the other, I could smell propane. So I've just been using the left side tank since that trip until I could determine the problem. I thought it may have damaged the valve on the right side tank.
    I brought the camper home today to give it a good cleaning and finally did the "soapy water" test on the valves, hoses, and regulator. The falling nut must have hit the right side of the regulator and caused a fracture in the housing. (see link to video below)
    So now I have to replace the regulator. If I had kept the cover on the tanks this probably would not have been damaged. And I should have the cover on to protect the lines from Sun damage as well. Oh well, lesson learned. [B)]
    https://www.dropbox.com/s/pc5otkyfyj3htw3/Leak in Regulator.MOV?dl=0
  2. kitphantom
    11,535
    732
    So far, the dual tanks, and auto changeover regulator have done well on both the pup and TT. The one on the TT is installed so that it faces the front wall, which is some protection. Not 100% of course. We had no LP cover for the pup, and the one for the TT is just too bulky. It interfered with the sway bar attachment and just won't fit on now that we have dual 6v batteries.
    We changed to the stainless braided pigtails a couple of years ago. This spring, I had a leak in the brass connector on one pigtail (one that rotates, not the connector to the tank), and the other pigtail clogged, so we now have a new set.
  3. PopUpSteve
    18,546
    1,394
    Dec 22, 2002
    Malvern, PA
    The main reason I took the cover off is because I'm using the Viking fiberglass propane tanks which are great but a tiny bit bigger (diameter wise) than steal tanks so a normal cover is really snug. So it's very difficult to get the covers on and off, like my pants after a pot luck PUP Rally dinner. [:D][LOL][LOL]
    Sjm9911 and neighbormike like this.
  4. Sjm9911
    3,621
    1,749
    You got lucky you smelled the propane, there is so many other ways that could have went down.
  5. tenttrailer
    3,105
    272
    Jul 18, 2013
    Thornville, OH
    Good catch.
  6. joet
    4,252
    753
    After you have replaced the regulator, have a propane lockdown preformed. This will tell of any leaks, no matter how small
  7. nineoaks2004
    6,819
    2,734
    Graceville, Florida
    Glad you found it before a much worse problem came out of the leak. Most regulators are easy to replace. BTW how good are the new fiberglass tanks ?
    Just goes to show that no matter how hard we try stuff still happens. Wonder where the nut came from and what it was used on ? Good Luck with the repair and keep on camping
  8. PopUpSteve
    18,546
    1,394
    Dec 22, 2002
    Malvern, PA
    By “nut” I mean the type that comes off a tree. I think it was thrown by a bunch of young squirrels having fun at someone else’s expense.
  9. Sjm9911
    3,621
    1,749
    PopUpSteve likes this.
  10. PopUpSteve
    18,546
    1,394
    Dec 22, 2002
    Malvern, PA
    It may have even been a fully laden African Swallow, I don't know.
  11. Sjm9911
    3,621
    1,749
    "What, A swallow carrying a coconut? "
