LT tires on camper??
Discussion in 'Tires / Brakes / Bearings / Axles' started by Rudy4536, Aug 11, 2018.
  1. Rudy4536
    Rudy4536 Member
    51
    Jun 13, 2018
    Hello campers,
    i just recently bought a Coleman e3. went to replace the tires since its a 2010. this camper is a off road model and came with LT 15" truck tires. ..my tire guy refused to put LT tires on a camper, he doesn't believe it was sold that way. i guess the question is can i run a LT tire?
    A 2ed rv place said basically the same thing. I believe the new Somerset e3's are still sold with the truck tires.
    I had a 2 hour drive home from picking up the camper and it tracked perfect. would a regular trailer tread tire track even better?
    Thanks for any responses
  2. joet
    4,156
    721
    Tag on side/front of camper will give you the needed info. It will list tire size, loading info and inflation
    A trailer tire will track the same
  3. WrkrBee
    WrkrBee Well-Known Member
    1,759
    638
    I put Michelins on mine. Rather have them than trailer tires.
  4. xxxapache
    2,718
    742
    Lots of people swap to LT tires on TTs.
  5. tombiasi
    4,974
    732
  6. Snow
    9,722
    801
    If your home State or Province allows LT tires, then there is no problem.
  7. tombiasi
    4,974
    732
    Just curious, if there is no problem why would some states or provinces not allow it?
  8. xxxapache
    2,718
    742
    What states do not allow it?
  9. tombiasi
    4,974
    732
    I don't know. I was just quoting Snow.
  10. roybraddy
    roybraddy Well-Known Member
    2,004
    640
    Mar 23, 2016
    King George, Virginia
    I use the BF GOODRICH ALL-TERRAIN LT235/75R15 on my OFF-ROAD POPUP TRAILER...
    It originally came with LT tires on it when I got it new in 2008...
    Roy Ken
  11. xxxapache
    2,718
    742
    I know....I want someone to show me a state that doesn't allow LT tires on a trailer.
    According to Tire Rack, LT tires as well as P Metric tires are rated for trailer use. You have to derated the sidewall rating on a P metric tire by 9%, though.
    https://m.tirerack.com/tires/tiretech/techpage.jsp?techid=219
    I know of at least one TT manufacturer that puts LT tires on new trailers.
  12. Fless
    Fless Active Member
    915
    177
    Aug 14, 2012
    Colorado
    The 2018 Forest River 17FQ TT I just rented for a week comes with LT tires from the factory.
  13. sleach
    670
    138
    May 17, 2014
    Boulder, Colorado
    Our 2012 Chalet Arrowhead Aframe came from the manufacturer with light truck tires. I know a lot of Colorado hunters, fisherpersons, mountain bikers and the like who use D and E-rated light truck tires on their trailers. Like us, they are looking for the tougher sidewall so as to reduce the chance of rock cuts and punctures on some of our more interesting roads. Earlier this year I replaced the 2012 dated tires with another pair of the same make and model.
  14. Snow
    9,722
    801
    I have no idea what States may or may not let LT tires be used on a trailer.. Basically, call your local DOT office and ask, if they yes you can, then your set..
    See where I am.. P-metric tires a.k.a passenger car tires, are not allowed on a trailer, period.. if your pulled over or caught in a safety blitz and you have car tires on your trailer, plate is pulled (plates are required here), trailer is deemed unsafe and gets a trip to the impound yard.
  15. WVhillbilly
    WVhillbilly Well-Known Member
    519
    354
    Jun 6, 2018
    WV
    Where is that?
    I want to make sure I never visit there.
    xxxapache likes this.
  16. nineoaks2004
    6,675
    2,607
    Graceville, Florida
    Fl allows you to put either LT or ST on the unit. The sidewall on the ST are a little heavier than the LT. but both work and as stated quite a few are going to LT tires for their unit.
  17. Fbird
    Fbird Active Member
    262
    113
    Sep 10, 2017
    Ferndale MI
    my parents bought a brand new aliner it came with p205/75r14. they held up fair. they did cup which is to be expected, it had a 3500lb axle and only weighed about 2000lb so it did a fair amount of bouncing.
  18. Rudy4536
    Rudy4536 Member
    51
    Jun 13, 2018
    Thanks all for the education,
    Many things I didn't know about tires. i know what I'm going to do now.
  19. WVhillbilly
    519
    354
    Jun 6, 2018
    WV
    Take your wheels off, go to a tire shop and pick out the new tires you want mounted on your truck wheels.
    Then put them back on the camper. :D
  20. Rudy4536
    Rudy4536 Member
    51
    Jun 13, 2018
    Yep! that's the plan.
