March 2019 - So what did you do for your camper this month?
Discussion in 'So, What Did You Do For Your Camper This Month ?' started by kitphantom, Mar 1, 2019.
  1. CamperChrissy
    CamperChrissy Well-Known Member
    525
    250
    Nov 25, 2016
    Chicago suburbs
    Finally retrieved our PUP from my uncle's yard, brought it home, and I was so happy to open it up and find NOTHING! No critters, no water, no mold, none of the bad things you dread. I was able to finish up the nice edges of the foam tiles I hurriedly installed last fall. Then I measured for and started making a PVC towel rack to hang under one of the bunk ends. Need to order some hardware to finish that up. Yay!
  2. kitphantom
    11,477
    695
    @DJNC- how old is that spare? Even if they look good, they can age out without ever seeing use.
  3. DJNC
    DJNC New Member
    Mar 20, 2019
    Winterville, NC
    Really do not know. I would go with your thoughts though and plan to replace it anyway. The debris all in it was driving me crazy so that’s cleaned up and I’ll replace the rubber.
  4. Garrity
    Garrity Member
    67
    23
    Feb 6, 2018
    Arizona
    There should be a date code on the side of the tire (search 'tire date code'). It's cheap insurance though to just replace it, but make sure you order that new cover!
  5. Sjm9911
    3,294
    1,537
    Yea , i need to get a cover for mine as well. This year i will get anothe 2 tires, long trip and the spare is old! It was part of the 2 year plan, lol. 2 tures last year and 2 this year. Ive been stocking up on stuff on amazon. Got a portable ellectric heater ( for the october disney trip), lots of odds and ends for the inside. Cant wait for a little warmer weather. I will make the bunk end shelves and add the pop up shelving over the sink.
  6. Buckmaster81
    Buckmaster81 Member
    72
    41
    Feb 27, 2019
    Long island NY
    What didn’t I do...
    Rebuilt the front trunk which included removing and replacing the water heater, access door and seals.
    Fixed a hole in the front plastic that was covered up horribly.
    Removed the roof racks
    Scraped off the old adhesive , cleaned and sealed the alumitite seams with eternabond tape
    Fixed a bunch of cracks in the trunk lid.
    3 new balances tires
    2 sets of bearings and bearing buddies
    Repaired the enterance step support arms.
    Repaired the entrance step lock/latch
    Oiled all locks
    Scrubbed the entire interior
    Washed the curtains
    Electrical systems check
    Greased the Wimble tree, leveling jacks, lift cables and pulleys.
    Inspected AC gasket
    Lubed bed slides
    Measured for new flooring
    Purchased LED bulbs and new bungee for bunk canopy.
    Still have a bunch to do to get it right.
    Then I gotta figure out how to camp!
    kitphantom, Sjm9911 and neighbormike like this.
  7. Sjm9911
    3,294
    1,537
    Your welcome to come over here and fix a few things!
    Buckmaster81 likes this.
  8. JWeible
    JWeible Member
    91
    46
    May 11, 2015
    Finally popped up our new pup! Figured out where everything will go and made a list of everything we need to get. Hubby is drawing up plans for shelving over the kitchen. Had to put her back down because it’s supposed to rain today. So excited to get camping!!!
    Garrity, neighbormike and Sjm9911 like this.
  9. Sjm9911
    3,294
    1,537
  10. BikeNFish
    BikeNFish Well-Known Member
    2,460
    1,441
    Apr 24, 2017
    Maplewood, MN
    I bought my tabs today! I can now legally bring the pup home from its winter sleeping place.
  11. kitphantom
    11,477
    695
    Didn't find a new sway bar in Tucson, so am using the one that had a piece break off. Working OK, not sure why that section breaking off seems to not cause a problem, but I'll take it.
    Dry camped 5 nights with the new batteries, which seem to perform better than the old ones did last year. They did well enough to loan my solar panel to another Sister on the Fly for most of an afternoon and part of the next morning.
    The microwave had shifted and screws on one side of the front frame had fallen out when I arrived in Tucson, and again at the SOTF event. Used matchsticks in the holes, no glue, and they held for my 3 hours on the road today.
    We will need to see why the fresh water seems to have more air in it than I remember when using it from the fresh tank. The pressure on the water pump holds, so it doesn't seem likely that we have a leak.
  12. generok
    generok Well-Known Member
    2,367
    512
    Feb 7, 2013
    Anchorage, AK
    I put four new tires on and tightened the set screws on the new hitch assembly. I had to get a 5/16" allen wrench, which was the one size I didn't already own.
  13. neighbormike
    1,852
    1,102
    Oct 6, 2012
    WI
    Planning on picking up the trailer next Saturday, so... remembered to make drain holes in battery boxes, ordered tire covers, a couple replacement lights... still dreaming of camping!
  14. Sjm9911
    3,294
    1,537
    I still jeed a tire cover! For the spare.
  15. vagov
    vagov Well-Known Member
    4,002
    219
    Aug 13, 2012
    Pittsburgh, Pa
    called the underground storage , made plans to pick up the trailer next Saturday morning
  16. neighbormike
    1,852
    1,102
    Oct 6, 2012
    WI
    Sounds like Hogan making contact with the underground! Lol
    hq308 likes this.
  17. brwarrior
    brwarrior Active Member
    147
    62
    Mar 26, 2017
    Clovis, CA
    Went and cleaned her up post Death Valley trip. Flushed the water heater out (and the gunk from the old anode rod) with the remnants of what was in the fresh water tank. I guess that "pressure washer" outlet (it's just a coiled vinyl hose with a sprayer on the end that taps off of the cold water line) has a use. And subsequently tracked more stuff onto the clean floor... Put the cover on as it's stored under a eucalyptus tree. Ordered and received some LED lamps for the porch and deck lights as well as a hitch stabilizer thing. Replaced the broken plastic screw that holds the glass top on the range. Just waiting for the clear 3M VHB to arrive to put the metal lip back on and a set of rubber wheel chocks. When I unhitched last time the plastic one didn't hold on the gravel and that was a little exciting. :O
    I'm contemplating changing out to LED turn/stop and markers. Or maybe just lamps. Looks like the tail lamps are going to need to be recaulked this year.
  18. Shaman1
    Shaman1 Well-Known Member
    1,935
    396
    May 13, 2011
    Oklahoma City, Oklahoma
    I checked the function of the fridge, freezer, heater and such to camping for my birthday. Sometimes it's how the camper returns the love we show them.
  19. Flipped in NH
    Flipped in NH Member
    48
    32
    Sep 6, 2018
    Groveton, NH
    Took it out of storage, set it up in the barn for inspection. No rodent signs! I also reinstalled the dinette cushions that I recovered. And one mattress enhanced with 2” gel-infused memory foam topper and then recovered. I am getting excited for the first trip in 2 1/2 weeks!
    Garrity likes this.
  20. Austin694
    Austin694 Member
    69
    Feb 18, 2015
    Re-caullked all the corner joints and across the awning, then painted the entire top with Hengs rubber coating.
