Marking your fuses
Discussion in 'Tow Vehicles, Hitch & Towing' started by Raycfe, Sep 3, 2018.
  1. Raycfe
    14,130
    987
    My truck has a fuse box under the hood with 80 spaces in it. Even though the cover is numbered, you would have to dig thru a 400 page owners manual to find what is what.
    So I made a little cheat sheet coated with plastic for under the cover. I also made sure I had a couple of spare fuses ..... just in case.
    This would make it a lot easier for me on the road if needed.
    I also have one under the cover of the campers convertor ....this would make it better to fine a problem in the dark on the floor.
    jnc and xxxapache like this.
  2. nineoaks2004
    6,264
    2,338
    Graceville, Florida
    Good Idea, thanks for sharing
  3. joet
    3,853
    611
    Mine has probably the same number of fuses and relays. But on the inside of the cover is a schematic showing each fuse and what its for
