Mystery Trailer Jack?
Discussion in 'Miscellaneous Repairs & Maintenance' started by nwcurt, Feb 12, 2019.
  1. nwcurt
    nwcurt New Member
    Sep 23, 2017
    So I've been looking through countless trailer jacks and not finding what I think I need. Wondering if I'm looking for something that doesn't exist.
    I have a welded on snap ring jack on my popup camper. I did the "axle flip" and now it doesn't offer me the range I want. Sounds like a simple fix, right?
    I think what I want is a snap ring mount (so I can just pop off the old and pop on the new), with 15" travel, folds up for travel, and has a wheel (or two). 1200# capacity is ideal. I'd be okay with 1000#. Side or top wind is fine.
    Seems like it would be easy to find, but I can't seem to track one down. Lots of 15" travel without a wheel. Some that are bolt on. Some that are 10" travel.
    Is there a reason a 15" lift jack that is snap ring with a wheel doesn't exist?
    Thanks!
  2. xxxapache
    2,628
    675
    Is there a reason you can't use your old wheel on a new jack?
  3. nwcurt
    nwcurt New Member
    Sep 23, 2017
    From what I tell, the new jacks that don't have wheels don't have removable stands where I could put a wheel on there. Wheels are available - and relatively cheap - but all the "inner tubes" that have the stand plate appear to be welded on.
  4. WrkrBee
    WrkrBee Well-Known Member
    1,342
    468
    Got a picture of your existing jack? Can you extend the length of your existing jack? Does it have room to swing out of the way with an extension?
  5. nwcurt
    nwcurt New Member
    Sep 23, 2017
    Well, I could take a picture, but the whole this is buried under 3 feet of snow right now. Record breaking storm has us stuck for 5 days straight now. Crazy!
    You might be on to something with the swing clearance. I'll check that when I can get access again.
  6. kcsa75
    kcsa75 Well-Known Member
    2,148
    858
    Sep 9, 2013
    Kansas City
    Have you checked with eTrailer? You can ask questions and one of their specialist will get back with you, normally within 24 hours. [:)C]
  7. nwcurt
    nwcurt New Member
    Sep 23, 2017
    Sure did. No response yet. They are pretty great, but I wanted to post it up here to the popup pros. Folks here have a much deeper knowledge specific to these campers for sure.
  8. Overland
    Overland Active Member
    169
    95
    May 1, 2013
    Bristol, Pa
  9. xxxapache
    2,628
    675
  10. theseus
    theseus Centerville, OH
    2,653
    301
    Feb 6, 2007
    Centerville, OH
