Need help furnace clicks but dosen't light its a duo therm 65900 camp trailer propane furnace
Discussion in 'Heating / Cooling Systems' started by Thomas1515#%, Feb 15, 2019.
  1. Thomas1515#%
    Thomas1515#% New Member
    Feb 15, 2019
    My furnace clicks like it wants to come on but dosen't light Im pretty sure it's getting gas any ideas?
  2. xxxapache
    2,703
    728
    Light a stove eye for a few minutes to purge the air from the gas lines.
  3. roybraddy
    roybraddy Well-Known Member
    1,990
    634
    Mar 23, 2016
    King George, Virginia
    The propane furnace has a safety air vane switch associated with the Furnace blower. If the air vane (i.e. Blower not working) is not working properly then it will keep the furnace from getting propane...
    Hopefully just purging the propane lines by burning your stovetop burners will fix you up...
    Roy Ken
    Thomas1515#% likes this.
  4. Thomas1515#%
    Feb 15, 2019
    I turned on the gas stove lit all burners for about 5 min then tried it again I turn thermostat on and up and it clicks and the fan comes on but only blows cold air any more ideas I can try I really appreciate the help
  5. Thomas1515#%
    Feb 15, 2019
    I tried lighting the stove burners for a few min still not working I noticed my thermostat is touchy when the kids bounced it would click click click of and on rapidly do u think it could be the igniter maybe burnt out how would I check it can u see the spark when u look in the little window when it kicks on?
  6. Sjm9911
    3,315
    1,549
    Jump the thermostat, then you can rule that out.
  7. theseus
    theseus Centerville, OH
    2,764
    364
    Feb 6, 2007
    Centerville, OH
    If the sail switch has gone bad, it will think it’s not moving enough air to light the furnace.
    kitphantom likes this.
  8. Thomas1515#%
    Feb 15, 2019
    It was the thermocouple thank you guys working like a charm now
    theseus, Sjm9911 and WVhillbilly like this.
