New awning doesn't fit in rail
Discussion in 'Canvas / Awnings / Add a Rooms / Tarps / Tents' started by B Lewis, May 21, 2019.
  1. B Lewis
    B Lewis New Member
    Oct 2, 2017
    I have an older popup and bought a new Dometic bag awning. The plastic guide on the bag awning that feeds into the rail is too small. The opening on the rail is too big. Is there an adapter of some kind available? Thanks!
  2. Shaman1
    Shaman1 Well-Known Member
    2,002
    414
    May 13, 2011
    Oklahoma City, Oklahoma
    I don't know about an adapter, but a new rail from coleman popup parts is about $80. Look under the roof section not the awning section.
    B Lewis likes this.
  3. megcabra
    megcabra Well-Known Member
    1,645
    418
    Aug 12, 2015
    Chapel Hill, North Carolina
  4. neighbormike
    1,924
    1,199
    Oct 6, 2012
    WI
    Just throwing this out there, but can you crimp the rail to fit?
    B Lewis and gladecreekwy like this.
  5. xvz12
    xvz12 Well-Known Member
    771
    403
    Apr 6, 2017
    New Plymouth, ID
    Just a thought....could you possibly get a length of 1/4" plastic tubing, like used for a swamp cooler or fridge water line, split it lengthwise, slip it over the plastic guide, then slip the whole thing into the rail? Dunno if it would work, but might be worth a try.....
    B Lewis likes this.
  6. GatorChamp44
    GatorChamp44 Active Member
    133
    34
    Mar 16, 2017
    Some of the prices on that website are disgusting.
    WeLoveCamping likes this.
  7. B Lewis
    B Lewis New Member
    Oct 2, 2017
    Thanks everyone. Will try crimping and if it doesn't work, will get a new rail. Was hoping to avoid putting a new rail on. We just did the roof with bed liner stuff last year.
  8. ezakoske
    ezakoske Active Member
    502
    57
    Nov 30, 2014
    Escondido, CA
    Is your rail aluminum or plastic? I'm assuming aluminum if you are considering crimping it tighter....
    Other options are:
