Newbie pump facuet question
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by Steffanie Walsh, Aug 17, 2018.
  1. Steffanie Walsh
    Steffanie Walsh New Member
    Aug 17, 2018
    We just bought a 1987 coleman chesapeake pop up. It does not have a water tank so when we hooked up the water to the camper the water came pouring out of the facuet and we couldn't get the facuet to shut off. What are we doing wrong?
  2. joet
    3,853
    611
    Welcome from the West Virginia mountains.. It would be helpful if you could post a picture of the facuet
  3. emoney
    emoney Well-Known Member
    879
    442
    Jul 7, 2018
    First things first; after the pic anyway, are you using a pressure regulator? Pup plumbing can’t handle what comes from a residential hose as the pipes are quite a bit smaller. So start there. Second there could be an issue with the faucet itself. It’s a pretty basic system; water comes in from the hose goes out thru the drain
  4. theseus
    theseus Centerville, OH
    2,651
    301
    Feb 6, 2007
    Centerville, OH
    Like emoney said, you need a pressure regulator. If the water pressure is too high, the faucet can't shut off. You can test this by barely turning the the water in the hose, if with the water barely on you can close the faucet, that's the problem.
  5. Steffanie Walsh
    Aug 17, 2018
    Here is the facuet. I tried turning the hose barely on but the facuet still is not shutting off
  6. Raycfe
    14,130
    987
    Make sure the handle is up all the way ...... and if you can look underneath the faucet that the water hose is connected to the center port.
  7. Raycfe
    14,130
    987
    The faucet is called a low-boy faucet.
  8. Steffanie Walsh
    Aug 17, 2018
    So we just installed a new facuet and tried the water on low and the new facuet wont shut off either could it be the city water regulator?
  9. Steffanie Walsh
    Aug 17, 2018
    Where would the pressure regulator be if the camper had one?
  10. Raycfe
    14,130
    987
    Sounds like the hose isn't connected correctly. IIRC the city water goes too the center and the other port gets capped.
