NTM 96 Jayco - Help with water system
Discussion in 'Plumbing Systems (The Fresh, The Blue, The Grey, &' started by OlyUSMC, Oct 15, 2018.
  1. OlyUSMC
    OlyUSMC New Member
    Oct 10, 2018
    After probing around my new pup, I see that there is a water storage tank. My lines are hooked up. How does water get to sink? Is there a pump that is supposed to turn on when the handle is pressed down?
    I see I will have to get a grey water tank too.
    Thanks in advance!
  2. Sjm9911
    1,987
    792
    Yes there is usally a pump , and a switch to turn it on. That is unless its a small tank and the flacuet is a pump version.
  3. Sjm9911
    1,987
    792
    What lines are hooked up? If connexted to a hose , that bypasses the tank and used the pressure from the hose instead. The pump uses dc, or battery power.
  4. OlyUSMC
    OlyUSMC New Member
    Oct 10, 2018
    image.jpg image.jpg I see the line from the city water and the line from tank both going to handle. I do not see a pump from tank. Pics...
  5. Sjm9911
    1,987
    792
    Sorry i dont have that brand of camper, and would be guesing at this point. If it has a tank ( and its big) it has to have a pump, or had one at one time.
  6. Raycfe
    13,885
    919
    Looks like you have a hand pump faucet. How about a photo of the top of the faucet/pump and we can get you a link to its operation.
  7. OlyUSMC
    OlyUSMC New Member
    Oct 10, 2018
    596F5A0F-A54F-498C-9A8A-D98C9657532B.jpeg Here it is
  8. Raycfe
    13,885
    919
    That's a "low boy" hand pump hers a link.
  9. TDS-MN
    TDS-MN Active Member
    456
    41
    Sep 29, 2013
    Minneapolis, MN
    Yup, that is a manual suction pump faucet. Operate the handle up and down a few times to draw water from the tank on each stroke.
    That is, if the hose is not kinked, and that the internal rubber bellows is in tact. The pump portion is re-buildable if you need, you can purchase a kit with new bellows and assorted other internal parts. The faucet should have provisions to control city water connection to pup via hose. I have never tried to operate mine in that manner, so someone else may be able to provide more insight to that function.
    OlyUSMC likes this.
