OK, how do you remove plywood from the aluminum skin?
Discussion in 'Miscellaneous Repairs & Maintenance' started by jessMN, Jul 13, 2019 at 4:22 PM.
  1. jessMN
    jessMN Member
    39
    May 18, 2019
    Minnesota
    my NTU camper had a corner seam open when we bought it and of course there was some water damage. Where the plywood got wet, it basically flaked off the aluminum, easy peasy - but the rest of it is on tight and I'm killing myself in 60% humidity attempting to scrape, pull and pry it off. Please tell me there is some secret to getting this off more easily?
  2. Anthony Hitchings
    290
    95
    Mar 2, 2019
    Harbor Freight Heat gun to soften the glue? (just guessing)
  3. WrkrBee
    WrkrBee Well-Known Member
    1,907
    710
    Maybe a handheld power planer. You can take off 1/8" or more in a pass. Once you get close, dial it back to 1/64" or less. Finish with a palm sander.
  4. jessMN
    jessMN Member
    39
    May 18, 2019
    Minnesota
    I actually have a heat gun and thought about that but didn't try it (honestly not sure why...)
    The plywood is only 1/8'....but a sander is a good idea if the heat gun doesnt work.
    Thanks!
  5. Blackripley
    Blackripley Member
    95
    61
    Jul 21, 2018
    Goleta Ca
    Steam or soaking the wood with water if you can isolate the piece.
    jessMN likes this.
