? on my Tekonsha Voyager brake controller
Discussion in 'Tires / Brakes / Bearings / Axles' started by suprz, Jul 15, 2008.
  1. suprz
    suprz may you never doubt yourself....
    1,400
    Feb 1, 2007
    first let me say that i have a Tekonsha Voyager brake controller, I had my brakes worked on in May of this year, (new pads and magnets) they worked great the first time out but since then they have stopped working, the second trip they didnt engage at all. I got back from that trip and checked my TV connector and found the blue wire and the ground wire were terribly corroded and grounding out against each other, i cleaned them and figured all was well. this friday i hooked up to go up to NH for the weekend and again no brakes! when i got home yesterday just for the heck of it, i pulled the manual slide control to see if the brakes would engage and they did. so now i am thinking the controller is just out of adjustment? the power dial is all the way up so it must be a problem with the "level" dial? what are your thoughts?
    1996 jeep cherokee 4x4
    2002 flagstaff 228 AKA "cool runnings"
    "just camp!!"
  2. ozzy1
    ozzy1 New Member
    127
    Jun 30, 2008
    Vermont
    Hey suprz,
    This might seem like a stupid question. But I'm going to ask anyway. Do the brake lights on your TV work? If the don't, you probably blew a fuse and that's why when you step on the brakes, your PUP brakes aren't working.
    During normal operation, your PUP brakes work off of the output side of your brake light switch. If you don't have any power to your switch re: blown fuse, your brakes won't work.
    The manual slide is for just a case like that. It works by bypassing your brake light switch. So if you do happen to blow a fuse such as your brake light fuse. You can still manually operate your PUP brakes.
    Also, there are some brake boxes out there that have a fused connection in the wiring, after the splice from the brake light switch. That fuse would be to protect your brake light switch in case of a short such as what you had.
    Clear as mud?
    Just trying to help!!
    Mike
    2008 Fleetwood Bayside
    2005 Chevy 2500HD Duramax
  3. suprz
    1,400
    Feb 1, 2007
    thanks ozzy1, my brake lights do work so i am hoping it is just the level dial. i am hoping the blue and white wire on the TV being shorted out didnt destroy the controller
    "just camp!!"
  4. recumbentman
    recumbentman Ventura, Ca
    207
    Apr 11, 2006
    suprz
    I have the same controller and I can tell you that yes if you forget to place the level dial pointing vertically straight down, the controller will not work correctly.
    don't ask how i know :)
    <center><img src=../Images/flags/us.gif border=0 align=middle alt="United States">05 Fleetwood Resolute<img src=../Images/icons/icon_smile_pu.gif border=0 align=middle alt="PopUp"> <img src=../Images/icons/icon_smile_suv.gif border=0 align=middle alt="Tow Vehicle"> 99 Ford Ranger /99 WinStar <img src=../Images/flags/us.gif border=0 align=middle alt="United States">
    <img src=../Images/icons/icon_smile_bike.gif border=0 align=middle alt="Bicycle"> Ride to Eat / Eat to Ride <img src=../Images/icons/icon_smile_bike.gif border=0 align=middle alt="Bicycle">
    <b>My</b> <font color=blue>MODS</font id=blue> Page</center>
  5. KISMETT
    KISMETT New Member
    17
    Jun 27, 2008
    I also have the same controller and you're right about the position of the level dial on the left. The level dial tells the control board how the black box is mounted on the dash. This controller activates by a momemtum switch. Similar to that of a pendulum. The controller can react to the situation accordingly. It will react slower going uphill than travelling downhill. It can sense a regular stop vs. a panic stop. Level dial positioning is crucial to its effectiveness. The older units sent a signal to the brakes at the same speed all the time, reaction time never changed.
    The dial on the right is for brake aggressiveness and trailer weight.
    Sorry,guys, I didn't mean to sound like a salesman. I'm just a RV technician.
  6. suprz
    1,400
    Feb 1, 2007
    KISMETT, thanks for the reply, is is normal for the "level" dial to be hard to turn? mine acts like it is stuck, i really have been lazy lately and havent hooked up the PUP to see if the brakes are working since i adjusted the "level" dial <img src=../Images/icons/icon_smile_sad.gif border=0 align=middle alt="Sad">
    "just camp!!"
  7. Erwin
    Erwin New Member
    524
    Mar 21, 2008
    Rochester, NY
    Suprz,
    You really need to follow the instructions on leveling the controller, not just point the dial down. It's fairly sensitive and does make a difference.
    Here they are:
    http://www.marksrv.com/brake_control/voyager_manual.pdf
    Me,DW,2 DS,2 SD (silly dogs)
    92 Rockwood XL1280
    03 Chevy Venture
  8. KISMETT
    KISMETT New Member
    17
    Jun 27, 2008
    Suprz,
    As Erwin stated, follow his link and use the set up directions step by step. You'll need both TV & pup hooked up and room for testing. All I did was get you in the ballpark to get some braking
    effect. I like to adjust it so that I feel just a little bit of pull from the rear when braking. That way none of the trailer braking is on my TV but I have a heavy trailer too.
    The level dial should offer some resistance but not be HARD to adjust.
