Over under axle question
Discussion in 'Tires / Brakes / Bearings / Axles' started by Mojeb, Oct 7, 2018.
  1. Mojeb
    Mojeb New Member
    18
    Aug 14, 2018
    so I moved the axle under the leaf springs on my pop up. Welded new perched on and used some new u bolts. My question is do I need to flip the middle bolt in the leaf springs so the bolt head goes into the perch hole ? Or is it ok going through the hole on the plate ?
  2. joet
    3,669
    554
    It will be ok, As long as the u bolts are tight it makes no difference as weather the bolt head or nut is seated in the perch
    Raycfe likes this.
  3. WrkrBee
    WrkrBee Well-Known Member
    1,072
    381
    In general mechanics, the bolt goes from top to bottom. If you lose the nut, the bolt is still there to hopefully hold stuff in shear until issue is discovered. In some designs, this is not possible.
  4. Mojeb
    Mojeb New Member
    18
    Aug 14, 2018
    Thanks for the replies. I’ll add it to the pre flight check list .
