Paint !!!
Discussion in 'Miscellaneous Repairs & Maintenance' started by slopitch@tent, Jun 8, 2019.
  1. slopitch@tent
    slopitch@tent New Member
    Mar 9, 2019
    It's time for paint ... got her stripped naked as a jaybird .. not to mention she is a 1989 jayco .. I'm going to foam roller this bad boy.. wanna know horror stories as well as if gloss worked for you or stick to matte finish.?? Any or all ideas welcome ☀️
    jmkay1 likes this.
  2. xxxapache
    2,739
    756
    If you are using oil based paint, you may want to consider adding Penetrol to it. Penetrol will make it flow better and leave fewer roller marks.
    slopitch@tent likes this.
  3. slopitch@tent
    Mar 9, 2019
    Will look into that it is getting a base primer ... just applied rustoleum elastomeric reflectivity paint to roof and can't look at it directly in sun that stuff is great.
  4. Sjm9911
    3,625
    1,763
    I would also use the smaller banana roller. For some reason it gives a smoother finish. Also dont forget to use tape or something to take the fuzz off the rollers. Nothing worse then a roller that sheads.
  5. tombiasi
    5,070
    827
    I'm not familiar with that camper. What is the material that you will be painting?
  6. nineoaks2004
    6,819
    2,736
    Graceville, Florida
    If it is aluminum, good idea to rub it down with vinegar, (keeps the paint from cracking after it dries)we used to do that aboard ship when I was in the Navy
  7. tombiasi
    5,070
    827
    Aluminum needs special prep and primer. That's why I asked.
  8. jerbear
    jerbear Active Member
    222
    44
    Jun 11, 2015
    Indiana
    I just re-did my 1995 Jayco roof .Re-sealed and painted with outdoor semi gloss 2 coats .It was the best outdoor paint I could get for $43 a gallon and I rolled the big areas with 3/8 in. nap roller and brushed the small spaces. It really looks nice.
    RIVERBELLE and Flipped in NH like this.
  9. jerbear
    222
    44
    Jun 11, 2015
    Indiana
    The paint I used did not require primer even on bare metal .I was prepared to use etching primer but the directions said I didn't have to . We'll see how long it last.
