plugging in 30 amp pop up into 50 amp at CG?
Discussion in 'Power - Site Power/Batteries/Generators/Solar' started by leningradka, Feb 8, 2019.
  1. leningradka
    leningradka Spending a small fortune to live like homeless guy
    257
    Apr 26, 2016
    Phoenix AZ
    Hi, Just booked a beautiful camp site but it has 50 amp service. I am reading conflicting info, so I figured I would ask the experts. All I need is an adaptor, correct? It will not damage my electrical systems to plug in my Coleman into a 50 amp service, is that right?
  2. BikeNFish
    BikeNFish Well-Known Member
    1,920
    1,072
    Apr 24, 2017
    Maplewood, MN
    A dog bone adapter will work just fine. You can’t plug into a 50 amp without it. 50 amp have four prongs, 30 amp have 3.
  3. Toedtoes
    Toedtoes Well-Known Member
    925
    586
    May 28, 2018
    Correct. Use a dogbone adapter not a puck style. And remember that just because you are plugged into a 50 amp pedestal, you still only have 30 amps - don't try to use more power than usual.
  4. leningradka
    257
    Apr 26, 2016
    Phoenix AZ
    Thank you. Is there anything particular I should look for in an adapter, or just anyone that fits the bill on Amazon?
  5. Toedtoes
    925
    586
    May 28, 2018
    Dogbone is the big deal. The ones with handles are nice and usually not expensive.
  6. tenttrailer
    2,935
    207
    Jul 18, 2013
    Thornville, OH
    That is true just the adaptor will work fine. But do remember. When connected to 30 amps, your service wire is protected to it's rating 30 amps via the post circuit breaker. When connected to 50 amps your service is not protected to it's rating of 30 amps because the post has a 50 amp breaker. Normally not an issue unless you are doing some heavy use of electric heaters and other electric things running off different breakers in the camper.
    Example running a heating element in your AC (1500w), running a 1500w heater on an outlet, running the fridge on AC, running your water heater on the 1300w elec water heating element, charging a low battery and miscellaneous other things like lights, etc.. If they all are running at the same time you are most likely drawing about 45 amps which should trip a30 amp post breaker. With a 50 amp breaker you would overheat the service wire unless you have a 30 amp main breaker in your fuse power distribution box.
  7. Snow
    9,347
    616
    I would suggest that you get the 50/30 amp adapter as well at the same time get yourself a 15/30 amp adapter. Get both of them in the dog bone style.
  8. Balthisar
    Balthisar Active Member
    151
    73
    Jun 26, 2018
    Plymouth, MI USA
    You might call the campground. In my state parks (Michigan), all of the 50 amps stands also have both 30 amp connectors and 20 amps connectors, too. You might not need an adaptor at all.
    kcsa75, bols2Dawall and Fless like this.
  9. leningradka
    257
    Apr 26, 2016
    Phoenix AZ
    thank you all, Balthisar, great idea!
  10. Snow
    9,347
    616
    Even if this campground offers 50/30/20(15) amp service on the post many places are slowly upgrading the posts to accommodate larger 5th wheels and MoHo's that run 50 amps. Seen it here in Ontario at a number of campgrounds, where 1 post is shared between 2 sites and that post now has 1-30 amp, 1-50 amp and 2-20(15) amp plugs, first come first serve to the 30amp plug.. So I would still buy the dog bones (50-30 and 15-30) just incase, I would rather have them and hardly (never) use them then need one of them and not have it. My [2C]
  11. Rusty2192
    Rusty2192 Active Member
    684
    199
    Jul 30, 2014
    Kentucky
    I’m with you on this. I keep a 50-30, 15-30, and a 30-15 all in the pup just in case. There are generic Chinese ones online for $15 a piece or less all the time or the Camco ones run on sale pretty often to that price.
  12. Toedtoes
    925
    586
    May 28, 2018
    I agree. They aren't expensive unless you wait until you are at a park and have to buy one from them.​
  13. tenttrailer
    2,935
    207
    Jul 18, 2013
    Thornville, OH
    We have been very lucky or the areas we camp its not a problem. In 2011 or 2012 I bought a 50 to 30 amp adaptor when I ran across one for about $8 on clearance. But have never used it and we camped those year I had it anywhere from 35 to over 70 nights a year. But had a need once before I bought it, and sure I will need it in the future.
    We are camping about 70% of the time with electric and 99% in State or federal CG's. Primary in the following states (OH, MI, IN, PA, NY, VT, KY, TN,WV, VA, NC, SC, GA, FL, AL, MS, LA)
  14. PopUpSteve
    PopUpSteve Administrator
    17,732
    867
    Dec 22, 2002
    Malvern, PA
    Always a good idea to be prepared for all power options at a CG.
    Toedtoes likes this.
  15. BillyMc
    BillyMc Active Member
    442
    136
    Mar 25, 2018
    We have a 15-30 puck that's been used for lighting to work on the camper at night. We now have a 20amp outdoor outlet so I bought a 20-30 dogbone adapter. I have checked out one CG that has some sites with only a 50amp connections so I'm watching for specials on 50-30 dogbones.
    *edited to correct my error
  16. Snow
    9,347
    616
    Just an FYI.. befor confusion starts. The dog bone and puck adapters are done male end first. i.e 50-30, 15-30 etc.. people get confused when all of a sudden they see someone type them backwards..
  17. BillyMc
    442
    136
    Mar 25, 2018
    In that case I have a 15-30 puck and a 20-30 dog bone and in the market for a 50-30. The 20-30 allows me use the AC while packing cleaning or working on the PUP. I used the puck for testing the AC, but it started getting warm after a few minutes. I've run it all day on the 20-30 dog bone without it warming at all.
  18. Dback2k4
    Dback2k4 Active Member
    320
    122
    Jul 16, 2017
    Iowa
    Every 50amp pedestal I've ever seen always has 20 or 15 amp service, but that doesn't help if you need to run 30. As previously said, use the dog bone style. I've got a 15 to 30 Puck for charging batteries at the house but I wouldn't use a puck where somebody else could potentially plug something in that would overload the circuit.
