Pop-up rides low
Discussion in 'Etrailer.com Trailers and Towing Forum' started by CampingCubFan, Jun 10, 2018.
  1. CampingCubFan
    CampingCubFan Member
    75
    Jun 26, 2016
    When we hitch our Palomino 4124 Y Series (light-weight) to our Toyota Sienna, there's a significant dip. The front end of the pop-up rides low. Is there any easy fix for this? We have a standard hitch with a brake controller, and often use a Swagman to carry bikes.
  2. eoleson1
    eoleson1 Well-Known Member
    1,801
    414
    Jul 5, 2011
    Macomb County Michigan
    Have you checked your tongue weight? It may be related to the way your trailer is loaded. Your tongue weight should be 10-15% of the trailer weight. If the tongue weight is in spec, two options would be a weight distribution hitch or spring helpers.
  3. Raycfe
    14,245
    1,017
    Does the van sag or do you need a different ball mount?
  4. durhamcamper
    durhamcamper Active Member
    684
    139
    Apr 21, 2010
    Pickering, Ontario
    I used Timbren suspension helpers on my previous tv. Very happy with the results.
  5. CampingCubFan
    75
    Jun 26, 2016
    I think I need a different ball mount. The van doesn't sag -- it's just not the same level as the pop-up.
  6. jnc
    3,904
    1,145
    Oct 1, 2014
    South Central New Hampshire
    Having the camper a little nose down isn't bad it's better than nose up. Do you Have a photo of your rig hooked up?
  7. davido
    davido Active Member
    857
    152
    Jul 17, 2014
    On the other hand, a little nose down is not a lot of nose down. As you requested, pictures would tell us a lot. But nose-down, I prefer to keep it within an inch or two of level.
  8. p
    p Active Member
    486
    92
    Jun 9, 2014
  9. Rusty2192
    Rusty2192 Active Member
    748
    239
    Jul 30, 2014
    Kentucky
    Mofonator likes this.
