Portable ac unit compressor issues
Discussion in 'Heating / Cooling Systems' started by lostboy, Oct 6, 2017.
  1. lostboy
    lostboy Active Member
    172
    40
    Nov 13, 2016
    Lakeville, MN
    I have a portable ac unit. When I plug it in my garage gfi outlet and the compressor kicks on it immediately trips the outlet. Fan will run fine prior to the compressor tripping the outlet.
    When I plug it in to another outlet in my house, I can hear the compressor kick on and then immediately kick off. The fan will continue to run and then it will try to cycle the compressor again but the compressor immediately shuts down again.
    Thoughts on what this could be?
  2. xxxapache
    2,701
    726
    Sounds like the compressor is locked up.
  3. kreeves
    kreeves She and her two dogs
    153
    26
    Dec 4, 2016
    West Virginia
    I'm guessing too much drawn on amps when the compressor kicks on, bit I'm not an electrician.
  4. lostboy
    172
    40
    Nov 13, 2016
    Lakeville, MN
    Kind of what I was thinking but it totally could be locked up to. If it draws to much at home then it would likely be to much for the camper right?.
    It is new so in theory should be fine. It is a sample from a previous employer so I can't return it but also paid very little.
  5. Douggro
    Douggro Active Member
    317
    66
    Jul 26, 2017
    Seattle, WA
    GFCI's are sometimes less tolerant of sudden hard loads. I'm more inclined to agree with xxxapache that the compressor has a fault. Could be locked up, or perhaps a limit switch is tripping. Either way, it doesn't look good for the unit.
  6. lostboy
    172
    40
    Nov 13, 2016
    Lakeville, MN
    Resurrecting my old post.
    Any chance anyone in MN (Minneapolis south metro) is looking for one of these and thinks they can fix this one. Yours free if you pick it up, it has been sitting in my garage since this post in the box that it came in. See above for issue.
    It's a cool living 8000btu.
