Portable Air Compressors...
Discussion in 'Tires / Brakes / Bearings / Axles' started by Rik Peery, Aug 14, 2018.
  1. Rik Peery
    Rik Peery Active Member
    399
    237
    Jun 15, 2018
    Virginia
    Saw a few responses from a year or so ago, wondering if there's a new kid on the block...checked mine, said 60 psi max cold (Load Star 205/75-14 Load Range C), left one at 50, right one 52...have a large JEEP pump w/ a gauge, dang thing nigh wore me out filling 'em up in the driveway; one the bright side, I now look like Charles Atlas, anticipating soreness by daybreak...looking for one that clips to the truck battery, compact, so easy the wife can use it, & under $200...
  2. tfischer
    tfischer Well-Known Member
    3,115
    653
    May 21, 2014
    You can get cheap ones (< $20) that plug into a lighter socket and they are slow but high PSI. Used one for years and still have one in each vehicle. I have a larger compressor I use in my workshop that I use for tires now.
    Rik Peery likes this.
  3. WrkrBee
    WrkrBee Well-Known Member
    1,314
    456
    The cheap ones have a duty cycle, like 5 minutes on and 10 minutes off. It could take hours to pump up a flat car tire. Most will overheat the first time they are used, because no one reads the warnings.
  4. joet
    3,853
    611
    I carry a battery powered pump that also has jump start capabilities. I know it will go to 100psi. Can't remember what I paid for it. Its a Peak brand
  5. Sjm9911
    2,656
    1,056
  6. Captain Smith
    Captain Smith New Member
    26
    Jun 28, 2012
    brwarrior, jsalexan7 and Rik Peery like this.
  7. jsalexan7
    jsalexan7 Flatlander
    61
    Aug 4, 2011
    Here's the one we have 5 of (one in each car and an extra we bought as a gift and forgot about that I loan out to the kids' friends when they inevitably need one on condition I get it back).
    They work pretty well, takes about 10ish minutes per tire to fill up from flat but very useful in a pinch. It'll actually shut itself down if it starts to overheat and if necessary, you can set it to the proper pressure and let it run, it'll shut off when it's at that pressure. That having been said, it's not the most accurate gauge on the planet, but will get you within about 5psi +- of your target pressure.
  8. tfischer
    3,115
    653
    May 21, 2014
    I haven't seen that on mine... if they have a duty cycle I've never run into a problem. Never filled up a car tire from completely flat, but have topped off car tires many times, and done plenty of bike and scooter tires with them all the way from flat.
    xxxapache likes this.
  9. nineoaks2004
    6,264
    2,338
    Graceville, Florida
    I keep one in my truck, I have had it for a long time and used it only once. I think I paid about $25.00 for it, it is slow but gives good pressure, just hook it on and hunker awhile while it did it's thing. It pumped up a friends slow leak tire so he could get home and get it fixed the next morning. Better to be prepared that suffer the consequences.
    (my opinion)
    tfischer, jsalexan7 and Rik Peery like this.
  10. xxxapache
    2,622
    665
    I have a cheap one in my camper. I have pumped several full size tires with it. I didn't set a stop watch, but would guess the time was less than 10 minutes.
    I believe this is the one I have:
    I have a 5 buck one that I took the housing off of. I carry it in my motorcycle saddlebag. I have plugged and pumped several tires on the side of the road for others with it.
    tfischer and Rik Peery like this.
  11. brwarrior
    brwarrior Active Member
    104
    38
    Mar 26, 2017
    Clovis, CA
    I have a Viair 88P (https://smile.amazon.com/gp/product/B005ASY23I/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). It will take my truck tires from 20psi to 50psi (gotta air down to drive in the sand on the beach) in about 5 minutes. I do all four without much resting. Just time to change tires (and the occasional pause to check pressure as the gauge is a little optimistic when it's running.) I have the extension hose but have yet to need it. Maybe with the PUP I will. I keep it in a canvas like tool bag that popped up with it on the big A.
    bearman512, Rik Peery and tfischer like this.
  12. generok
    generok Well-Known Member
    2,304
    429
    Feb 7, 2013
    Anchorage, AK
    I've got one I bought heck, 25 years ago maybe? It has a nifty light on it. I've used it over the years to touch up tires on the road. I used it on the PUP once. IMHO, these things are "get me home" items you keep in the TV or PUP. If it's the ONLY thing you have to maintain your tires at home, I don't know, maybe spring for something nice. I have a full size compressor in the garage, and do 99% of my tire maintenance in the driveway, so the portable just rots in the storage compartment in case of an emergency.
    This one seems nice... its the only one with over 2 CFM free flow rate...
    https://smile.amazon.com/dp/B074DD3NS5/ref=psdc_155346011_t1_B005ASY23I?th=1
  13. silverfz
    silverfz Active Member
    721
    45
    Aug 8, 2013
    I have a power kit that has usb and air compressor . Just got a ryobi one that uses the same battery as my impact wrench . The impact wrench is to put stabilizers down, remove lug nuts and with put air .
  14. Jeep Guy
    Jeep Guy Active Member
    158
    76
    Mar 7, 2018
  15. Rik Peery
    399
    237
    Jun 15, 2018
    Virginia
  16. Spaceace5150
    Spaceace5150 Member
    108
    17
    Oct 1, 2014
    My trailer tires are at 80 psi. Anyone have any experience inflating to that high of a psi?
  17. SteveP
    SteveP Well-Known Member
    1,160
    242
    Either of the Viair pumps, 88P or 90P, mentioned above will do it. I use the 90P also. Better off using a pump with battery clips than a ciggie plug. They pull more amps, run cooler, and fill the tires quickly, just run the engine while using them for high pressure.
  18. gladecreekwy
    417
    384
    Sep 25, 2016
    Good advice on the battery clips. Using a cigarette lighter plug will blow that fuse eventually. I also have a 90P, very happy with it.
  19. Rik Peery
    399
    237
    Jun 15, 2018
    Virginia
    Mine are 60 psi cold, used a big JEEP hand pump, told myself no mas, ordered the Viair as mentioned by SteveP & Glade, good up to 120 psi, I can use it for the wife's Crosstrek & my 2 Tacomas as well to keep 'em topped......
  20. xxxapache
    2,622
    665
    Everyone needs a compressor....I just counted up. I have 45 vehicle or trailer tires plus bicycles, lawn equipment and a four wheeler.
    gladecreekwy and Rik Peery like this.
