Portable air conditioner?
Discussion in 'Heating / Cooling Systems' started by jenswan, Jul 29, 2016.
  1. jenswan
    jenswan New Member
    Apr 29, 2013
    Has anyone ever used a portable air conditioner in their pop up? It's hot so much of the year here in Texas that I'm thinking of getting one, and wondered if anyone has any experience with them?
  2. mchance47
    mchance47 New Member
    107
    May 16, 2016
    Sure. I used a 10k BTU model that cooled us off and kept us cool. You can't run it from your battery, but if you have a generator or a 30+ amp electrical hookup, you'll be fine. You'll have either one or two hoses to fit in a window, but that's not hard to set up.
  3. kitphantom
    11,479
    697
    If you look around the Portal, you'll find ideas to use a portable a/c in a pup. One thing to remember is that you are cooling something that is mostly tenting, not an insulated house. Folks do Refectix inserts and other heat/cold retention measures to help keep the coolness in.
  4. cyclop5
    cyclop5 Member
    104
    Jun 18, 2015
    I bought an 8k btu model a couple months ago. Hardest part is venting our the exhaust air. (I don't want to cut another hole in anything). I'm currently contemplating venting it up through the vent on the roof (corrugated plastic is awesome to work with btw) but haven't gotten that set up yet.
  5. xxxapache
    2,703
    729
    I used an 8500 btu in my Apache.
  6. ny_rocking_chairs
    ny_rocking_chairs Active Member
    266
    42
    Jul 17, 2016
    Webster, NY
    Would people mind posting what models they have and if they like them? Also starting to look into these.
  7. upstate family
    upstate family Member
    198
    18
    Jul 20, 2016
    Central New York
    Portable a/c is in our plans for our pup too.
  8. kcsa75
    kcsa75 Well-Known Member
    2,420
    990
    Sep 9, 2013
    Kansas City
  9. terry1419
    terry1419 Active Member
    670
    80
    Mar 6, 2016
    Streator, IL
    Looks like 10K BTU.
  10. xxxapache
    2,703
    729
    A 10k unit will work fine if you have some shade. In full sun, I bet it will struggle.....Most RV AC units are at least 13500 btu.
  11. Nandy
    Nandy Active Member
    2,257
    Mar 29, 2010
    Pugs will go a lot of way. I used an 8k btu window unit while camping in florida for an entire week and it worked great to the point the wife asked me to turn it down at night. We were in the camper a few times during the early evening and while it was not freezing it was cold and comfortable. My pup is a 7' box with canvas, I bet one with the saturated vinyl canvas would have done even better.
  12. mchance47
    107
    May 16, 2016
    We've got LG's 10k BTU portable. Works great.
  13. A+Tqwest12A
    A+Tqwest12A New Member
    Apr 1, 2019
    Noblesville, IN
  14. eoleson1
    eoleson1 Well-Known Member
    1,934
    472
    Jul 5, 2011
    Macomb County Michigan
    I set mine on the counter. Running the exhaust was pretty easy. The unit should come with a panel to exhaust through a partially open window. I took the exhaust hose with the window adaptor and just zipped it through the side wall of the camper. We had it exhausted on the back side of the camper so we didn't have to walk through the hot exhaust leaving the pup.
  15. A+Tqwest12A
    Apr 1, 2019
    Noblesville, IN
    That's a good point about location and heat from the exhaust. I also read that people suggested running the plug out to the camp site hook up rather than on the PUP. Suppose you could run it out the same window as long as the hook up is on that side.
  16. Sneezer
    1,430
    460
    My supplemental A/C sits on a small counter between the bunk and the slide out dinette. I have the hose routed to vent out a side window on the dinette. I bought a stealth flow gutter drain adapter and used some reflectix to make it fit into the hose. This way the window zips tighter to the hose outlet. I also run a dedicated power cord to the pole.
  17. crackerJack
    crackerJack Well-Known Member
    1,102
    277
    Jan 6, 2014
    Scottsville, KY
    The standard 13,500 BTU roof top unit would not keep up with our 12’ box in the sun on the gulf coast.
    Maybe because it was old or to small?
    I swapped to a new 15K and solved the problem. Overkill? IDK
    I just don’t want to fool with PUGS.
    xxxapache likes this.
  18. WrkrBee
    WrkrBee Well-Known Member
    1,735
    629
    In full sun, the 5,000 BTU AC in the Aliner is a vacuum cleaner. We run a small swamp cooler to help on the other end of the camper. It turns back into a AC about sundown. Go big. You have paid for power at campgrounds.
  19. GreyFox
    GreyFox Well-Known Member
    894
    389
    Oct 10, 2018
    S Ontario
    Yeah, overkill. PUGs are only part of the solution, in really hot temperatures (and really cold) you want to be using Reflectix window inserts which make a HUGE difference in keeping the interior of any camper with tenting cool in really hot weather and warmer in really cold weather. They'd be especially effective for those using portable A/C units which in most cases will be rated with less cooling capacity than a standard roof mount 13,500 BTU A/C.
