Portable air conditioner
Discussion in 'Heating / Cooling Systems' started by Solo camper, Apr 11, 2019.
  1. Solo camper
    Solo camper Member
    69
    23
    Apr 23, 2018
    West virginia
    Wondering if anyone has any experience using a portable air conditioner. Looking for input from using one in a pop up or even in a room. I am considering purchasing a cargo trailer and wonder if this would be an acceptable substitute for a roof mount. Would definitely be cheaper.
  2. tfischer
    tfischer Well-Known Member
    3,318
    843
    May 21, 2014
    I use one in the garage when woodworking and we have brought it along on a few camping trips in the pup. Ours is a two-hose which is more efficient than the single hose ones that are more common.
    Blackripley likes this.
  3. xxxapache
    2,740
    759
    I used a 8k btu in my Apache for 8 years. With solar bunk and window covers it did ok in direct sun. In the shade it did great. I have used the same unit during power outages at my house. I shut some doors and was probably only cooling about 500 sq ft. However, it was 90+ outside and cold enough to need a blanket inside.
  4. Sneezer
    1,438
    469
    I have an 8k btu portable. I use it to help supplement the roof A/C during the TX summer. Mine is a single hose model, and not as efficient as the dual hose ones, but I got it for 50-75% off, so I can't complain much. I have a large pup - dual king beds, slide out dinette, and the portable alone can't make a dent in the heat. I had it running one day last year due to an electrical problem, and it was sweltering inside. This was in a site with close to full shade, awning deployed, pugs all around and reflectix in almost every window.
    For a small trailer you might be OK if you take the effort to properly insulate. I know the van folks often install a portable to cool the interior, and I have seen others mounted on outside with ducting to go into a homebuilt trailer. If you do go this route, I would get the biggest unit you can afford and fit.
    We have a 10k btu portable at the house that we bought when the main unit died at home - we couldn't afford to put a new unit in at the time so we had to make do with a window unit in the master and a portable for my son's bedroom. In that circumstance it did an admiral job of cooling the room, keeping it at 73-75 during the day, and down to 69-70 at night. I think it would have done better if we kept his door closed, but the cats needed to move between rooms during the day.
  5. Blackripley
    Blackripley Member
    99
    63
    Jul 21, 2018
    Goleta Ca
  6. kcsa75
    kcsa75 Well-Known Member
    2,535
    1,069
    Sep 9, 2013
    Kansas City
    We had a floor model AC in the Pup. I don't know how big it was but it would freeze you out in Kansas in July.
  7. eoleson1
    eoleson1 Well-Known Member
    2,082
    579
    Jul 5, 2011
    Macomb County Michigan
    We have a 10k unit that we use in the house and in the pop up. With no extra shading or insulation the camper isn’t what I would consider cool with temps in the 90s and sun on the canvas, but it’s not miserable either. After the sun goes down and the temps fall into the 80s or lower, the pup cools down nicely.
    xxxapache likes this.
  8. Spaceace5150
    Spaceace5150 Member
    130
    21
    Oct 1, 2014
    Is there anything special that needs to be done electrical-wise for these portable a/c units? I just purchased one for my house and planning taking along on a camping trip.
    Camping in a 2014 Rockwood 1640ltd with electrical hook ups.
    Thanks!
  9. eoleson1
    2,082
    579
    Jul 5, 2011
    It depends on the electrical system in your pop up. Mine was "prewired for AC" which meant there was a 20 amp circuit that didnt have anything on it except one outlet. We plugged into that and had no issues. We just set it on the counter and ran the exhaust hose out the back screen.
    kcsa75 likes this.
  10. Spaceace5150
    Spaceace5150 Member
    130
    21
    Oct 1, 2014
    I also have been told that my pop up is prewired for AC. How did you find that outlet on the 20 amp circuit?
  11. eoleson1
    2,082
    579
    Jul 5, 2011
    When we bought ours, there was an electric box in the dinette that had a blank cover marked 'for ac.' I had to put the outlet into that box.
  12. dbhost
    dbhost Active Member
    512
    194
    Sep 19, 2018
    League City, Texas USA.
    I have a portable AC, that is a 2 hose model, 12.5K BTU @110v, made by Royal Sovereign.
    The good.
    - It will freeze you out of a fairly good sized room in July. Our home AC is weak, and my AC guy is a side gig kind of AC guy so we are putting off full replacement until the fall when he won't get cooked in the attic, and I can afford the rest of his services. We use it for the main part of the house instead of the central unit as it is MUCH cheaper to run right now.
    - Cost wise, portable units are far less expensive than roof top units.
    The bad.
    - The condensation has nowhere to go except the catch pan, once full, the AC turns off, or the catch pan overflows. I set mine up on a riser, keep the plug out of the drain pan and put an aluminum steam table pan under it to catch the condensate.
    - They suck up more floor space than I would be willing to sacrifice in a camper.
    - Mine at least, was far less than reliable, I had to dig into it myself and repair a broken squirrel cage fan that was never attached correctly at the factory. I do NOT recommend Royal Sovereign products period.
    - Compared to other style air conditioners, portables just aren't as efficient to use. Only reason mine is more efficient in the house is my central AC is dying and sucks energy like Dracula at a blood bank.
    An alternative.
    To keep your build costs low, AC efficiency high, and eliminate the drawbacks of a portable unit. Seriously consider one of the following...
    - A small mini split ductless system. Known to be efficient, but cost more than...
    - A small window unit A/C. Depending on the size cargo trailer you are building out, and how much insulation you use if any at all, the smallest 5K BTU units, which go for just over $100.00 and can run easily on a cheap Harbor Freight 700 watt generator, would be more than enough.
    Most small pop ups, camper van conversions, truck campers etc... that are using window units, are using 5K BTU units. One thing I would HIGHLY suggest though, is that you use Henry TropiCool on the roof to help control heat in your trailer. You'd be shocked to see the difference a little thermal coating does. Insulation during the build also helps, a LOT. Even if it's just a layer of reflectix...
    While not a pop up, I have been involved in one Camper Van and a camping / cargo trailer conversion.
    The cargo trailer was a 7x16 with a 7' interior height. We used 5K BTU Window unit AC at the nose of the trailer by the bedroom airea, rolled Henry Tropicool on the roof, and lined the interior with a layer of R-Max, I believe it is R5 with a radiant barrier, between the outer skin and interior walls. The owner uses it to take his family to various racing events and is able to keep the trailer cool and comfortable even in the Texas summer heat.
  13. xxxapache
    2,740
    759
    Mine had a tube that runs through the exhaust hose for the condensate. The hot air makes it a mist that goes out the exhaust.
    kcsa75 likes this.
