Power converter
Discussion in 'Wiring' started by Buddababy, Apr 16, 2019.
  1. Buddababy
    Buddababy New Member
    Apr 16, 2019
    LaVerkin,Utah
    Hello.new to site.so here I go.....
    Have a Komfort t.trailer. Have beeping coming from converter. Worked fine on 120V but when I hooked up the 2 -6 volt batteries along with shore power the converter started to BEEP. The converter is old and no longer made. It works on only 12v and only 120 Volts ....What the heck?????
  2. tenttrailer
    3,096
    262
    Jul 18, 2013
    Thornville, OH
    Are you sure the battery is connected correctly.
  3. Buddababy
    Apr 16, 2019
    LaVerkin,Utah
    I assumed it was because the lights & stove fan works. BUT i will check it again when it stops raining...Thanks
  4. tfischer
    tfischer Well-Known Member
    3,262
    787
    May 21, 2014
    Do you have a gas detector near the converter? They will beep if there's low voltage.
  5. tfischer
    3,262
    787
    May 21, 2014
    Also could you clarify what you meant by:
  6. Buddababy
    Apr 16, 2019
    LaVerkin,Utah
    I meant that it did not beep when I had it connected to 120 v.nor did it when hooked to 12 v. BUT when both were connected it beeped and beeped
  7. Buddababy
    Apr 16, 2019
    LaVerkin,Utah
    also no gas detector. this trailer is a 1979 model. No gas detector and i doubt that there was even gas back then;)
  8. jmkay1
    4,328
    1,276
    Question, does your batteries have enough juice? Because your camper is so old it won’t charge your battery’s in tow. I wonder if your converter is able to sense low power.
  9. SteveP
    SteveP Well-Known Member
    1,249
    289
    If you have the original converter it will not work on shore power and battery power at the same time, but you should be able to connect both. There should be a 3 way rocker on the panel to switch from battery to converter.
    My guess would be that you have the batteries connected in parallel rather than series and you're only getting 6 volts, the beep would be a low voltage signal. Incandesant lights and fan will work off of 6 volts, but better of of 12. Read http://www.marxrv.com/12volt/12volt.htm.
  10. Buddababy
    Apr 16, 2019
    LaVerkin,Utah
    Batteries are new 6 volt wired in series. Not sure if it is original converter.Would guess yes as nobody around here knows anything about it. can not find a disconnect to eliminate either 120 or 12 v on converter.
  11. tenttrailer
    3,096
    262
    Jul 18, 2013
    Thornville, OH
    It could be a trouble code. Is there a break in the beeping? If so you need to google that converter for a manual.
    I still am wondering if the leads coming from the converter to the battery is missed wired (backwards). It is easy to do, most campers used Black as the plus and white or green as the ground (neg). Most of the circuits in a camper will work if connected backwards. But if the converter is connected to the battery backwards it has to charger from -12V to +24V that is a total of 48V. Maybe it starts to charge hits a protection mode, beeps and turns itself off, than tries again???
  12. roybraddy
    roybraddy Well-Known Member
    2,004
    640
    Mar 23, 2016
    King George, Virginia
    Here is a neat diagram pictorial on how to hookup 6V batteries wired in series... Note the 220AH does not double when wired in series - only the DC Voltage
    Google Image
    Here is a similar diagram pictorial on how to hookup two 12VDC batteries in parallel. Note the 12VDC stays the same but the 210AH doubles when wired in parallel... Also note the NEG LEAD connection position. This gives equal cables lengths for best performance of the batteries...
    Google image
    Roy Ken
  13. Buddababy
    Apr 16, 2019
    LaVerkin,Utah
    no break in the beep sound. tried to google the make and or mfg. for info but could not find any info. Used the RV for 4 days camping and converter worked great on 2, 6volt batts. hooked in series,no beeps. only when put 120 volts and 12 v. together.
