Progressive Brake Controller
Discussion in 'Tow Vehicles, Hitch & Towing' started by Ken Lane, Apr 24, 2019.
  1. Ken Lane
    Ken Lane Active Member
    113
    63
    Apr 16, 2019
    Knoxville TN
    My new Curt Echo came last night via UPS. I had heard that European vehicles (my GLK included) can be finicky with the seven wire connector TV plug. I thought that the Echo with its Bluetooth connection might be the easiest way to go. It looks like it is very simple to set up so I expect as long as U haul gets the connector wired right I will have a plug and play situation with the brake controller. Now my chimpanzee brain is worrying how I can check the quality of the wiring at the U Haul store at delivery this Saturday. I would hope they have a dummy load tester they use to ensure their wiring installation is correct and use the same tool to demonstrate it to me. Anyone have any experience with a U Haul installation that included the wiring? Did they have a tester they used to show the wiring was functioning correctly? I want to go get the camper after hitch install on Saturday and need to make sure was done correctly.
  2. WrkrBee
    WrkrBee Well-Known Member
    1,733
    629
    I keep a 4 pin and 7 blade tester in the truck all the time. Probably about $15 for both. [​IMG]
  3. Ken Lane
    113
    63
    Apr 16, 2019
    Knoxville TN
    Wow that will be easy to pick up and cheap too.
  4. WrkrBee
    1,733
    629
    Amazon.
  5. xvz12
    xvz12 Well-Known Member
    753
    388
    Apr 6, 2017
    New Plymouth, ID
    When I installed my 7-pin TV connector, I got one with the test lights built into it, I like it.
    Ken Lane likes this.
  6. Sjm9911
    3,315
    1,548
    I here u haul is top notch for trailor hitch and wiring. I havent used them , but a lot of people here and freinds of mine recomended them to me. So , you should be good.
  7. Ken Lane
    113
    63
    Apr 16, 2019
    Knoxville TN
    I have ordered the test device from Amazon. Thanks for the great info all.
  8. Adam H
    Adam H Active Member
    354
    124
    Aug 22, 2015
    I guess U-haul has gotten better over the years. Last time I saw their wiring jobs it was loaded with scotch locks and bare wire hanging out of a tail light...
  9. Sjm9911
    3,315
    1,548
    Might be the area also, were opposite coasts.
  10. bheff
    bheff Active Member
    283
    63
    Feb 24, 2011
    Hopefully they do well. No way would let Uhaul here touch my vehicle. The wiring is simple enough, so I just do my own. I know it is done right. Tuesday a co-worker asked me to install his hitch and wire the lights. He isnt very mechanically inclined but he helped and learned a ton.
