Propane-on or off when not camping?
Discussion in 'Propane - Got Gas' started by Nanapoppypops, Apr 16, 2019 at 6:23 PM.
  1. Nanapoppypops
    Nanapoppypops Member
    35
    Mar 30, 2019
    Just purchased our popup, 2009. The dealer did not turn the propane off and the knob oncamper was turned to high. We will not be camping for awhile. Should we turn it off?
  2. gladecreekwy
    410
    377
    Sep 25, 2016
    Off when not camping and towing for us.
    PopUpSteve and xxxapache like this.
  3. NMroamer
    NMroamer Active Member
    416
    170
    Apr 21, 2016
    Albuquerque NM
    If you really have to ask the answer is yes turn it off.
  4. Toedtoes
    Toedtoes Well-Known Member
    1,090
    669
    May 28, 2018
    There is no reason to have it turned on when you are not using it. And it is safer to turn it off.
    Byrd_Huntr and xxxapache like this.
  5. jmkay1
    4,034
    981
    Off. Dealers are notorious to leave something on. They killed my battery a couple times by not disconnecting it. Although leaving the propane on is scary.
  6. kitphantom
    11,361
    583
    With our popups, we always kept the LP off except when we were in camp. We only had a stove (in both) and a furnace (in the second).
    With the TT, if we have the refrigerator running, which is most of the season, we have the LP on. (It lives in our driveway.) We started leaving the LP on when we arrived home right after the power went out, and the fridge was trying to run on LP. In the off-season, and any other time the fridge is off, the LP is off too.
  7. Raycfe
    14,115
    983
    Propane off when not using it.
  8. nineoaks2004
    6,236
    2,327
    Graceville, Florida
    I always turn my propane off,
  9. PopUpSteve
    PopUpSteve Administrator
    18,007
    1,029
    Dec 22, 2002
    Malvern, PA
    OFF!
  10. generok
    generok Well-Known Member
    2,302
    429
    Feb 7, 2013
    Anchorage, AK
    In the PUP, I kept it off at home until I went to light the fridge for pre-trip cool down.
    In the TT, I usually keep it on because once we load up, we keep the fridge running all the time. If the power fails, I want it to go back to LP.
  11. tfischer
    tfischer Well-Known Member
    3,115
    653
    May 21, 2014
    Just like your gas grill at home... turn the tank off when you're not actively using it.
    Byrd_Huntr and neighbormike like this.
  12. kcsa75
    kcsa75 Well-Known Member
    2,118
    844
    Sep 9, 2013
    Kansas City
    When we had the Pup I always shut off the propane when we weren't using it. But since we got TT I got lazy. It has two 30-lb tanks and a hard cover. It's kind of a pain to take on an off so once I turn the propane on at the beginning of the season, I just leave it one.
    generok likes this.
  13. Nanapoppypops
    35
    Mar 30, 2019
    I did! This was done by the dealer. This is our first pop up and if I hadn't opened up the small door to where the knob is to turn on and off, I probably would not have realized it was on.
  14. Snow
    9,511
    674
    Install a "boat deck inspection plate" into the plastic cover, when you want to turn on/off the propane, you unscrew the inspection cover, reach in to the valves.. Did this on out Outback's cover and it makes it so easy..
  15. Nanapoppypops
    35
    Mar 30, 2019
    That's sounds like a good idea. Thank you.
  16. nhlakes
    nhlakes Well-Known Member
    622
    294
    Oct 15, 2011
    DE and NH
    It's standard procedure to leave the propane on while towing with travel trailers and motorhomes. Otherwise the fridge and freezer (larger than pups) would not work. Most are not 12v. You may have to turn off the propane for some tunnels where there is signage and a pull-off to do so. Some tunnels (like the Chesapeake Bay Bridge Tunnel) direct campers to a specific lane where they will ask you to confirm your propane is off. You just turn it back on when you exit the tunnel.
    Agree with the access panels. My cover has a thumb screw access panel to turn off tanks. Would be a pain without it. I also cut in a small window up front so I could see when the auto-switchover indicated that a tank was empty.
    kcsa75 and kitphantom like this.
