putting window ac unit in a 1998 coleman westlake pop up????
Discussion in 'Heating / Cooling Systems' started by rover69, Jan 9, 2010.
  1. rover69
    rover69 New Member
    Jan 9, 2010
    due to the famous coleman ABS roof sagging due to roof top AC. I am wanting to install a window unit AC unit in my 1998 coleman westlake. (IS THIS POSSIBLE) I also want to perform this application so I can use camper at home in lieu of dealing with 30 Amp issues. Please help!!!! Thanks
  2. kitphantom
    11,546
    736
    I am not familiar enough with pup models to tell you if it is possible in yours. However, I can say that our small [6' box, one bed end] Palomino Shetland had a home a/c the original owner had added. What he did was to cut a hole in the front wall, move the LP tank cradle forward on the tongue, and put some angle iron on to make a support for the a/c. I assume it had worked well enough, it looked like it had been in there for at least several years, the camper was at least 10 years old when we bought it.
    We took it out immediately, we almost always camp where there are no hookups, so it would have been dead weight. We are finally going to move the LP tank back to where it should be, it is very easy to scrape knuckles on it when we crank the wheel.
  3. samtgrizz
    samtgrizz New Member
    869
    Jun 3, 2009
    San Antonio, Texas
    Here is a thread that was posted earlier this year that you might find helpful.
    http://www.popupportal.com/index.php?topic=28553.msg188761#msg188761
    Good luck.
  4. 3pillons
    3pillons Press hard, Five copies.
    532
    Feb 8, 2009
    Winder GA
    Here is my install.
    http://www.popupportal.com/index.php?topic=28075.msg153882#msg153882
  5. dgarbers
    dgarbers New Member
    394
    Oct 30, 2008
    GA
    Can you handle the weight of that kind of A/C unit? When we started out, we didn't think too much about the weight in the pup, but have since "traded" out as much as we could, finding lighter weight items in an effort to get our over weight issues under control.
