Radial vs Bias Ply Tires
Discussion in 'Tires / Brakes / Bearings / Axles' started by ravis78, Aug 6, 2018.
  1. ravis78
    ravis78 2002 Rockwood Freedom 2280
    Apr 22, 2015
    I have never had any experience with bias ply tires. Until doing some research I did not even realize it was something that was used on pups.
    We had a flat(tread separation) while towing this past weekend on a set of Carlisle Trial Radial 145R12 Load Range E that were from 2012. We have a 2002 Rockwood Freedom 2280, dry weight 1847 and GVWR is around 2500.
    I will be replacing all 3 tires. I have always been very happy with the radials but wonder if the bias ply will do any better. Pup is stored inside on jack stands when not in use. I have way more than enough truck to tow and would like to have a higher speed rating tire.
  2. Sjm9911
    2,980
    1,259
    From what I've been reading, is that the radials are better for road travel, heat, and tracking. The bias is older technology. They say tires dry rot after 5 years, so depending on that, your speed and lubrication that could have contributed to that.
  3. Pnut
    Pnut Member
    58
    24
    Jul 8, 2018
    NE Georgia
    Stick with the radials. Bias ply are old tech and are used by manufacturers because they are cheaper, not because they are better.
  4. xxxapache
    2,667
    700
    FWIW, a bias ply usually causes less damage than a radial in the event of a failure.
  5. megcabra
    megcabra Well-Known Member
    1,481
    375
    Aug 12, 2015
    Chapel Hill, North Carolina
  6. myride
    myride Well-Known Member
    772
    347
    May 14, 2015
    Edmonton, AB
    Radials over bias especially if your more highway miles. Bias are old tech....there's a reason most manufacturers now put radials on over bias.
  7. joet
    3,992
    671
    Since you store inside, the tires should last longer, UV light causes Dry rot
    How does one lubricate a tire.
    Radials will run cooler than bias, and heat is a tire killer.
  8. Sjm9911
    2,980
    1,259
    Lubrication on the hub. Not the tire.
  9. Lanternman
    Lanternman Active Member
    133
    154
    Aug 17, 2017
    Mooresville NC
    Swapped out the bias plys on my little Starcraft for radials and will never go back. Per the 'hand test' they definitely run cooler, and although the majority of us dont tow over 65mph or so anyhow, its nice peace of mind to know you're running 65 with a tire rated for higher speeds, than right on the limit of 65 that most ST bias plys are rated for.
    Just my 2 cents.
    myride, megcabra and Sjm9911 like this.
  10. silvermickey2002
    4,488
    300
    Sep 11, 2008
    Morris County, NJ
    I replaced the bias-ply with radials and will never go back. The pup sees all highway. The radials run cooler and seems to ride better. That is to say does not seem as bouncy as the bias ply at least from the rear view mirror perspective! Yes, they cost a little more but last longer. The radials I have are rated for 80 mph.
    These are what I have and I know yours are 12":
    https://www.etrailer.com/Tires-and-Wheels/Kenda/AM10210.html
    myride and Lanternman like this.
  11. Lanternman
    133
    154
    Aug 17, 2017
    Mooresville NC
    Yep. Mine are Kenda Radial trail RH, size ST145-12 which should be the equivalent to the standard issue 5.30/12 bias plies.
