Raising suspension
Discussion in 'Tires / Brakes / Bearings / Axles' started by DLass40, Aug 30, 2018.
  1. DLass40
    DLass40 New Member
    Aug 27, 2018
    Hi,
    New guy here. We have a NTU 2000 Coleman Niagara. I am looking to raise the PUP ride height up a bit. It bottoms out barely going in and out of the driveway...
    I am aware of the "axle flip" but I am only looking to raise it up an inch or two. We currently us a 2x6 to keep from bottoming out in the driveway. There is another set of holes in the front of the spring mounts that could give us a little bit of lift. Anyone use these or even know about them?
    Any other suggestions will be appreciated!
  2. gladecreekwy
    336
    327
    Sep 25, 2016
    Why not the flip?
    DLass40 likes this.
  3. Matt Benoit
    Matt Benoit Active Member
    302
    162
    Jul 30, 2017
    Warren, MI
    Do the flip, you won't regret it. Best mod I've done!
    DLass40 and gladecreekwy like this.
  4. Halford
    Halford Well-Known Member
    3,440
    439
    Sep 28, 2011
    Santa Clarita, California
    I am thinking about it, too. Never got around to it yet. Might raise like 5 to 8 inches
  5. Matt Benoit
    302
    162
    Jul 30, 2017
    Warren, MI
    You will need more than just a "flip" to get 8in lift. You could use blocks between the axle and springs in combination with the flip. Or you could have some custom leaf springs made-up. It would give you the lift you want without lift blocks and huge ubolts lol.
  6. DLass40
    DLass40 New Member
    Aug 27, 2018
    For now we like the 100% unobstructed view in the rear view mirror. Plus we only need an inch or so to clear driveway and I could probably move the mounts myself.
  7. DLass40
    DLass40 New Member
    Aug 27, 2018
    Attempting to add a pic...
    This is the front spring mount. The rear seems welded
  8. Raycfe
    13,885
    919
    Yes move the bolt
    DLass40 likes this.
  9. joet
    3,559
    512
    To gain a little more you can replace the spring shackles with longer ones
    DLass40 likes this.
  10. William Freeman
    William Freeman Active Member
    145
    55
    May 5, 2018
    Richburg SC
    Yeah, looks like that would give you an inch.
