Rebuild kit for my Atwood coupler?
Discussion in 'Etrailer.com Trailers and Towing Forum' started by Rich Knack, Aug 13, 2018.
  1. Rich Knack
    Rich Knack Member
    69
    May 25, 2018
    Charlevoix, Michigan
    The coupler on my 1978 Rockwood still latches onto the hitch ball okay, but the safety catch is worn out and no longer will prevent the lever from flipping up. I have to tie it down with a small bungee cord. Is there a rebuild kit available? Rather not have to pay someone to cut the old one off and weld on a new one...
    20180813_103122.jpg 20180813_103105.jpg 20180813_103020.jpg 20180813_103013.jpg
  2. SteveP
    SteveP Well-Known Member
    1,124
    235
    That hole in the side of the release lever is for a hitch lock or safety pin. A lock or proper sized safety pin will provide more security while towing. Tractor Supply has the best selection around here.
  3. Rich Knack
    Rich Knack Member
    69
    May 25, 2018
    The pin through the hole is SUPPOSED to prevent the safety catch from moving, that keeps the lever down. That is the little piece sticking up out of the top of the lever in the pictures - you pull it back in order to unlatch the lever so you can lift it up, normally. That safety catch is worn out. You can put a pin in that hole - I HAVE one - but you can still pull the lever up. That is why I said I need to rebuild it.
  4. jnc
    3,896
    1,139
    Oct 1, 2014
    South Central New Hampshire
  5. Rich Knack
    Rich Knack Member
    69
    May 25, 2018
    That one is meant for a Husky coupler. Will it fit my Atwood?
  6. jnc
    3,896
    1,139
    Oct 1, 2014
    Thy have a bunch. Take your a part and find on that looks the same.
  7. Rich Knack
    Rich Knack Member
    69
    May 25, 2018
    No rebuild kits are available for my old coupler any more, since Atwood got bought out. Ended up buying a new one from Tractor Supply Corp and having it welded on (same time as the new stabilizers).
  8. Shaman1
    Shaman1 Well-Known Member
    1,483
    195
    May 13, 2011
    Oklahoma City, Oklahoma
    Glad you got it fixed. Happy camping.
