Remove 3 way Fridge and install a window AC?
Discussion in 'Heating / Cooling Systems' started by D in AZ, Dec 13, 2018.
  1. D in AZ
    D in AZ New Member
    Dec 13, 2018
    Has anyone removed their 3 way refrigerator and installed a window AC in its place? We don't use the refrigerator, and a 5-6000 btu window unit would fit into the space nicely. Just wondering if it has been done. Thanks!
  2. nineoaks2004
    6,661
    2,602
    Graceville, Florida
    If you do this the AC will be low, you will need a deflector to get the air higher, I did something like that and made a deflector out of a piece of thin plexiglass it worked good for me.
  3. joet
    4,150
    721
    And a 5-6K BTU A/C isn't enough to keep a pup cool. The roof top units are 13-15k BTU
  4. davido
    davido Active Member
    862
    158
    Jul 17, 2014
    If you are camping at below 82f fine, but then why bother. ;)
    Otherwise, probably under powered relative to roof top RV air conditioners, and blowing cold air at your feet where it will mostly stay thanks to the laws of thermo-convection.
  5. Sjm9911
    3,374
    1,577
    Im thinking he could fit in a bigger unit. Additionally sometimes just getting the moisture out of the air makes the heat more barable. So maybe a 6000 btu ac , while not getting the pup cold might help make it comfortable. The pups do get hot though, so i would go bigger.
    Lebowski16 likes this.
  6. davido
    862
    158
    Jul 17, 2014
    Sounds reasonable assuming the install can be well done.
  7. jnc
    3,909
    1,157
    Oct 1, 2014
    South Central New Hampshire
    I think the biggest problem is the Heat the AC will create if it's not sticking out the side of the Pup.
  8. jmkay1
    4,318
    1,262
    I've seen something very similar done. They had to use multiple fans to push the air off the floor. Even then it still struggled to get it in the bunk ends. I considered using a window unit on a shelf outside in my old camper. Cutting a hole in the screen to get it in the camper. That way it would be higher off the ground and hopefully the air will stay above ground level longer. Ultimately when my old camper died before I tried. I then decided a rooftop AC was a must on my next camper. I just didn't think a window unit will be enough in a popup. Especially in the temps I've camped in.
  9. GreyFox
    GreyFox Well-Known Member
    916
    403
    Oct 10, 2018
    S Ontario
    The most common size of RV A/C is 13,500 BTU, mounted on the roof for one simple reason - cold air falls, hot air rises. A 6000 BTU A/C mounted lower down in the side wall of the trailer obviously won't be anywhere near as effective, however it will be better than nothing. That said, any A/C will deal with the heat load far more effectively by using Reflectix in each of the six bunk end windows, as well as PUG solar covers over each bunk end. Blocking the bunk ends off from the camper's main body during the day would also help.
  10. joet
    4,150
    721
    A 13.5k BTU has a hard time keeping a pup cool in the heat of the day. A 6K is only half of BTU's the 13.5 unit. It won't begin to make a difference
  11. GreyFox
    916
    403
    Oct 10, 2018
    S Ontario
    Disagree. Using PUGs over the bunk end tenting and Reflectix window inserts our 13,500 BTU Carrier AirV would freeze us out of our Santa Fe even when camping in southern states in the summer.
  12. joet
    4,150
    721
    Must have something wrong with my new unit. Even with a duct temp of 48 degrees it never would get cold enough to freeze us out inside. How would a 6000 BTU unit keep it cooler or as cool as than a 13,000BTU unit.
    If the mfg.'s could get by with using a smaller unit, (cheaper) they would.
  13. WrkrBee
    WrkrBee Well-Known Member
    1,746
    635
    Our 2018 Aliner Scout has a 5000 BTU AC under the back bunk. It is too small for even the 12' Aliner with no dormers. The conditioned air never makes it off the floor, unless we use multiple fans to move the air away from the return and one fan on the dinette aimed up to push the warm air down from the peak. It's worse at night when you pull the bed out. Then the conditioned air aimed up, hits the bottom of the bed, then hits the lip of the pull out and is forced down. This forms an AC cave, since the return air vent is under the bed too. It is a terrible design.
  14. GreyFox
    916
    403
    Oct 10, 2018
    S Ontario
    You're conveniently disregarding what I said, which was - "Using PUGs over the bunk end tenting and Reflectix window inserts ...". Keeping the interior of a tent camper comfortable in really hot weather isn't just about generating cold air but retaining as much of that cold air and not letting it leak out through the tenting, nor letting the sun bake the tops of the bunk ends. Makes a BIG difference.
  15. joet
    4,150
    721
    I guess I got bad PUG's also
  16. GreyFox
    916
    403
    Oct 10, 2018
    S Ontario
    Maybe, but in an A-frame trailer what other choice is there? [?:~{] Your roof won't support the weight of a 100 lb roof mount A/C so the trailer body is the only other place it can be located. In the OP's case no one is arguing that a roof top A/C wouldn't be the best solution, but that's not the point. He merely wants to remove the fridge which he isn't using anyway and use that space to locate a window style A/C. It may not be an ideal solution but will be better than nothing at all, especially if he takes the advice to use PUGs and Reflectix window inserts, along with a fan or two to help better distribute the air inside the camper.
  17. GreyFox
    916
    403
    Oct 10, 2018
    S Ontario
    PUGs alone help, PUGs + Reflectix inserts make a BIG difference. Try it, you might just be surprised at how effective this combination can be.
  18. Sjm9911
    3,374
    1,577
  19. WrkrBee
    1,746
    635
    Older Aliners had the AC in the side of the camper, where the conditioned air could be aimed up and was not compromised at night.
  20. GreyFox
    916
    403
    Oct 10, 2018
    S Ontario
    The OP wants to mount an A/C in the side wall of his camper as well, I'm sure that directing the cooled air upwards wouldn't be much of an issue at all.
